Question about Sony Playstation 3 (PS3) Console
PICTURE LAG WITH HDMI HOOKEP TO RCA 42'' L42FHD37
Everytime i put in a blueray disc on my ps3 it gets a LITTLE picture lag wich is anoying!!
PS: This doesnt happen when i change the display to the yellow, white and red cables. ONLY ON HDMI :(
    Problem Solver:
  • 14 Answers
Check in your TV's settings for a selection called "Game mode" It will turn off the scaling chip in the TV(The PS3 will scale the image anyway) and remove the lag it was producing.
Posted on Jan 04, 2009
I have a RCA L42FHD37 LCD TV. It comes on with picture and sound. After about five minutes the pictures color turns pink and green but still has clear picture and sound. What causes this to happen?
T'Con board fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 19, 2014 | RCA L42FHD37 42 in. LCD HDTV
I have picture but no sound through my hdmi connection. I tried a hdmi to vga converter but have the same problem.
When using VGA, you will need to run another cable from the audio out of the other device to the red and white RCA connectors on the back of the TV labeled Audio Input (left & right).
Sep 08, 2013 | RCA L42FHD37 42 in. LCD HDTV
I have a 2 year old RCA L42FHD37 LCD TV. Sound is working but I have no picture, any suggestions?
Tv turn on now,does it have a flashes of pictures only few sec. than dies have sound left only?Yes,than those 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Dec 27, 2010 | RCA L42FHD37 42 in. LCD HDTV
Just got an xbox 360 slim 250GB but when I went to play halo 3, the game was lagging along with the xbox menu itself. I even connected a plug-in controller and I had the same result showing that it was not...
If you just bought it brand new, then return it for an exchange. Its not wise to keep an electronics appliance or game console that is having issues straight out of the box. Using your A\V (RCA) cables instead of an HDMI cable shouldn't be causing any lag, at least nothing that is significant enough to notice.
Aug 17, 2010 | Microsoft Xbox 360 Console
Insignia lag with X Box
Turn game mode on and put your xbox in hdmi 3 and if that doesnt work go to picture settings then advanced setting and turn dcm off
Feb 21, 2010 | Insignia 42" LCD Flat-Panel HDTV
No sound for my ps3
There's a set-up menu in your ps-3, you have to change the menu from analog to digital output.
Kind regards, Gerard
Oct 19, 2008 | LG 42LC2D 42 in. LCD HDTV
Time lag between Playstation 3 and LCD TV.
SOURCE: http://boardsus.playstation.com/playstation/board/message?board.id=confrontation&thread.id=735278&view=by_date_ascending&page=2
If your playing with lag on your new HD LCD your at a competitive disadvantage! Everything you see happens seconds later than your opponent who has his/her settings right.
The fix:
1. Connect your PS3 using HDMI Input 2.
2. SELECT or RENAME the HDMI Input to PC. Already pointed out, but this does not make the majority of tv's run in PC mode.
3. On the PS3 start-up menu go to Settings---> Display ---->
Choose HDMI ----> DO NOT choose AUTOMATIC ----> SELECT CUSTOM ----->
4. Now, Select all the Resolution options EXCEPT 720p. This will force your games into 1080p mode. What it will also do is drop any game that doesn't have 1080i/p support into 480. Games like Burnout Paradise, Vegas 2, Heavenly Sword, NHL 08 and more will be dropped into SD (480) rather than HD. Your picture will be terrible. 720p is standard gaming resolution currently, 1080i/p is not.
5. Save and complete the display setup.
6. Turn off the PS3. Turn off the TV.
7. Turn on the TV. Turn on the PS3.
8. Complete! (Lag eliminated). Please spread this around!
*The key to eliminating ALL LAG is modern LCD's need to be in PC MODE (NOT GAME MODE) On many tv's, PC mode requires you to use a VGA or DVI connector. You'll either need to buy an HDMI adapter or an HDMI to VGA / DVI cable if that's the case.
and the Source MUST BE IN 1080p so that the TV can use it's NATIVE RESOLUTION.* Please, check your tv's native resolution. If you have a plasma that only does 720p, your native resolution is probably 720p. You do not need to follow these steps, it will only make things worse. If your tv's native resolution is 720p, obviously you want to keep your display settings at 720p on your PS3. If your native resolution is 1080i, you shouldn't go selecting 1080p. If your native resolution is 1080p on your TV, you need to be aware that removing 720p as an option will force many games into 480.
Keep these things in mind and remember that the steps above are far from a cure all solution. .
Lag gone! Worked for me! (SAMSUNG LNA52850)
Source : http://answers.yahoo.com/question/index?qid=20081225141902AApX7cJ
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
"Lag" during play
Have you tried playing the game with the controller connected to the PS3 via the USB cable? Also, just as a test, DISABLE the Internet connection option on the PS3's menu to see if it makes any difference. I found that for some reason some titles (namely Enchanted Arms) have been know to act erratically with an active Internet connection whilst playing.
Aug 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
336 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
