Question about Tools & Hardware - Others
I have a 2500 watt honda harmony generator that will not give enough electricity for power tools
    Master:
  • 796 Answers
Does it give enough electricity for anything else, or none at all?
Posted on Dec 22, 2013
How to find portable generator brands?
There are numerous sites online that are providing specifics of portable generator. These are typically specially manufactured for those people who are looking for good quality portable electrical generator and it's assessment. To find out more please click here.
Best Selling 2000 Watt Portable Generator Brands 2016 Top Brands Guide
Aug 05, 2016 | Electrical Supplies
I HAVE A GENERATOR HONDA E2500.
the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
Dec 06, 2015 | Honda Generator E2500 Vintage Great...
How many watts does it need to run the airconditioner.Is a honda 3000 good enough
You can check the AC unit, it will tell you how much electricity it needs. Likely 15 or 20 amps. That's about 1500 or 2000 watts. What does your generator supply?
Jun 23, 2015 | Honda Electrical Supplies
Hi , I have a 2500 watts honda generator , it's starts & sounds alright but when you plug a power tool and once you press the trigger of tool it shuts off right away ... What could be the problem ?
Wow, you must have one mighty bit power tool there. The Honda genny should accept it easily. You don't mention the current draw of that power tool - it should be under approx. 2200W to allow for start-up load. The other possibility is an excessively long power cord or even a short-circuit in the tool ...... or a problem with the genny itself! Try plugging in your wife's hair dryer to check it. Failing that you should get an electrician to check it all out.
Good luck.
Sep 01, 2014 | Electrical Supplies
My 3000 watt honda generator doesn't seem to put out the proper power
http://cdn.powerequipment.honda.com/pe/pdf/manuals/31ZT7601.pdf
I would check spark arrester and clean it and the muffler first.lt could be the inverter unit. If you have a meter determine the output voltage, and freq. You would need a scope to look at waveform the repair should be lest to a repair center. suggest you call Honda for more guidance.
You could spend a lot of money on maybe parts./
Nov 30, 2017 | Honda 3000 Watt Portable Generator
I have a 1996 lance camper with a 2500 onan generater lp cant get the spark plug out can you help
Spray the plug base with a good penetrant and give it time to seep into the threads and work.
Failing that you can sometimes carefully heat the head around the plug with a small hand torch and get the head to expand enough to enable you to break the spark plug loose.
Apr 12, 2011 | Watts Onan Portable Generator - 4000 ,...
I need to know what gauge wires black and red for battery to generator
This is what I assume is for the starter motor for the generator. I would use for this a #8 welding wire style cable. This will supply enough power for starting.
Jan 30, 2011 | Honda Mmd 5000 Watt Electric Start...
PF 2500 watt generator... Need plug and oil
30wt oil, probably a Champion RN4C plug. Could give link to a manual if part / model number of generator was provided.
May 17, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
Honda generator em 1800
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
Nov 28, 2008 | Electrical Supplies
Tools & Hardware - Others Logo
26 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
