Question about Mitsubishi WS-55809 55" Rear Projection Television
CANNOT USE MY TV UNLESS CABLE BOX OR DVD PLYER IS ON
I HAVE THE MISUBISHI DIAMOND SERIES PROJECTION 55 INCH TV DOES NOT WORK UNLESS MY CABLE BOX IS HOOKED UP AND IF I CHANGE MY INPUT 1 2 3 4 TO HOOK UP A GAME OR CAMERA I GET FUZZY GREEN LINES CANNOT SEE PICTURE .. EVEN DIRECT LINE FROM CABLE SAME THING..
    Genius:
  • 1,199 Answers
Your TV sounds like its signal board has went out and will need replaced (This is the most common cause of the problems you describe!)
Please rate response and help keep this site FREE!
Posted on Jan 03, 2009
Mitsubishi WS-55613 55 color out
the problem is on the cables , look on the back of the cable box , if it is hd box the on ly thing you need to do is put the cables base on there colors green with green , red and blue , the other 2 are for video , but if it is normal box just put the yellow color with yelow on your box to your tv and the other to are audio
Jan 27, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Have a misubishi ws55859 green light blinks will not turn on it all started when the tv was unpluged
The dm board power circuit has gone bad and would require many capacitors to be changed. This board is a box (metal grey) on the left extreme as viewed from rear next to input connector board. It is not recommended as an abinitio DIY Project. Caps faults are difficult to find and require an ESR meter. Call for professional help and should cost 180 to 220. Check it out at www.fixurtvs.com for more questions and price quotes.
Feb 26, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Timer light on projection TV blinking and TV won't turn on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Mar 25, 2009 | Mitsubishi WS-55807 TV
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Diamond shield
It seems these TV's are going bad right and left. I would look on Craig’s list for a cheap/free 55" Diamond TV. Not sure what you would do with the left over TV. I just picked up a 55" Diamond for free and hope to fix it. If I don’t get it to work, you can have the screen (California).
Aug 03, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS55513
misubishi, ws55513, clear screen cover, diffuser screen, need some leads as to where to get them
Feb 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
