Question about Samsung RL44ECPS Bottom Freezer Refrigerator
Smasung fridge freezer rl44ecps been on vacation mode now has reset back to normal but fridge not cooling help !
Had been on vacation setting must have been pressed by accident reset to normal setting but fridge not cooling !
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Posted on Apr 01, 2008
  • 9 Answers
SOURCE: Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Posted on Sep 06, 2008
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
SOURCE: Vacation button keeps on activated(refrigerator Samsung SRS20NTC)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Set to regular temp then lock functions.
Freezer temp + fridge temp for 3-8 sec to lock function
Posted on Apr 21, 2009
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
My refrigerator display shows "Of" how do I get it to normal when I reset the temp for the fridge or freezer the display goes back to "Of"
I just had the same problem with my Samsung. OF means it is in demo mode. On my fridge I had to press "Energy Service" key and "Power Freeze" key simultaneously for at least 3 seconds to bring the fridge out of demo mode. Hope this helps.....
Jan 28, 2013 | Samsung Refrigerators
Can get my fridge freezer off the vacation button
This is list of refrigerator problems,which is normally faced in refrigerator.
You can go through the details,by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Dec 22, 2012 | Refrigerators
Turning off vacation botton
HI DARREN.top off my head try pressing and hold for a few seconds.normally that should do it.if it doesnt try unpluging for 10/15 minutes and re plug.good luck Ali
Aug 22, 2012 | Whirlpool 20TBL4 Side by Side Refrigerator
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
We have a Kenmore Elite Freezer Model #253.29082994. We had the freezer plugged in and it was working fine. We unplugged it and moved it and now when we plug it in it won't start. Is there some kind of...
You refrigerator was made by Frigidaire Adaptive Defrost Controls Frigidaire Refrigerator Trouble Shooting and Diagnosing
On the initial plugin, or when power is restored to the fridge after a power outage:
If terminating thermostat is open, the fridge enters a compressor (cooling) cycle.
If the terminating thermostat is closed, the first defrost cycle occurs 1 hour
after initial plug-in.
Maximum defrost cycle time is 24 minutes.
Minimum time between defrost cycles is 6 hours. (compressor runtime)
Maximum normal clock time between defrost cycles is 12 hours.
Maximum time between defrost cycles (in "vacation" mode) is 72 hours.
Vacation mode is not entered unless the door has not been opened in at least 24 hours.
Note that the ADC will only enter the defrost mode if the terminating thermostat is closed. If the terminating thermostat is open when defrost is initiated, the ADC board will wait for six minutes and then return to the cooling mode.
ASSUMING that the fridge has been on and running,
and the terminating thermostat is closed,
defrost is initiated by pressing the door (light) switch
at least five times within six seconds.
The defrost heater should start heating up within 8 seconds.
If the above procedure caused the heater to heat up, the ADC board is probably bad; replace it.
If the defrost heater does not heat up, test the defrost heater, terminating thermostat and cold control for continuity as follows:
Unplug the fridge from the wall. Unplug the ADC board from its connector.
Test the connector for continuity between the following leads:
Defrost Heater = DEF TERM (blue) to DEF OUT (brown).
Terminating Thermostat = DEF TERM (blue) to NEUTRAL (lt blue).
Cold Control = COLD CONTROL (orange) to L1 (black).
Replace the defective component.
dvfxnxxsllnll3xsyszyldhiovfnqznnvujbtluyw2q4uxl2ntjkcdj6njhpmxnefkntwws4bi9kdg83ay5nd0jdsnhpljetrth0supsduvxugpczlkyaszhzu1onu9xwdfjv0xta0jidtfiwg%3d%3d
Apr 26, 2011 | Kenmore Freezers
Samsung RL44ECPS Bottom Freezer Refrigerator Logo
47 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
