Question about ASUS P5S800-VM Motherboard
CMOS Battery low e CMOS Date/Time not set - ASUS P5S800-VM Motherboard
mellomania
  • 121 Answers
SOURCE: loses CMOS settings
there is a jumper near the board cmos battery. try to clear cmos by changing the jumper to the other position for some seconds (while power is off) so smos is clear.
turn the pc on hit delete to enter setup and load system defaults then exit saving configuration.
Posted on Nov 11, 2007
melnavz
  • 1226 Answers
SOURCE: faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Posted on Mar 13, 2008
colliewob
  • 778 Answers
SOURCE: CMOS Checksum error.
the only thing i can think of is when you changed the battery somehow the board terminals positive negative are not in proper contact with battery
did you try resetting bios by the pins on the motherboard
somewhere on the board is printed bios reset or words to the effect
most times it is a 2 pin connector with a jumper only on 1 pin connect the jumper across both pins remove and try to reboot
hope this helps
Posted on Jul 25, 2008
  • 4 Answers
SOURCE: asus mother board p5rd1 vm
plz update your bios
Posted on Apr 01, 2009
dlundmark
  • 797 Answers
SOURCE: I INSTALLED A NEW CMOS BATTERY BUT STILL NO EFFECT
Just replacing the battery will not set anything. You have to do the setting of the values. If you can run setup by pressing F1, then do that and set all the settings and then save before exiting. Make sure you save the settings by choosing the correct exit and re-boot option.
If the settings cannot be set nor saved, then make sure the poser is off or pull the plug from the wall outlet, then short the bios with the jumper to short the bios. This will reset the bios to the default settings. Turn on the system and then go to the bios settings and set the settings. Then use the reboot option to save the settings.
Posted on Nov 06, 2009
ASUS ALL IN ONE computer ET2221i-b85 The time is not correct and keeps losing time. I want to replace the cmos battery .
Keeping time has always been a problem for computers, as their internal clocks needed something to synchronize with. If you have an Internet connection and use Windows, you can get the time adjusted regularly using a time set function from Windows online. The CMOS battery will have little to do with time settings, unless it goes bad. Then, not only will your date and time go out of sync, so can many other settings in the CMOS. So, unless you are getting a low battery warning, or both the date and time are out of sync, you probably don't need a new CMOS battery and replacement probably won't fix you time drift issue.
In Windows 10, to get auto time sync, go to "Settings", then select "Date and Time". Under this you will see an option to "Set Time Automatically", as well as to select your time zone.
Aug 19, 2016 | ASUS Computers & Internet
How do I check the battery for low cmos.?
If the CMOS battery is low or dead, the system will force you to enter the current time and date into the BIOS each time the machine is turned on. If it boots normally and retains its settings then the battery is OK.
Mar 08, 2015 | Computers & Internet
How do I fix my CMOS Battery Low error so I can correct the Time and Date since it's stuck on the 01/01/2004 date and won't save in my BIOS?
This is usually a very short and sweet step to complete.
After you have changed the CMOS battery over to a new one all you should have to do is go into BIOS set the date, the time and the year. Save the settings in the BIOS, exit and restart the computer.
You have to set the date, time and year in the BIOS first then change it on the desktop.
The proper battery to use for CMOS is a C2023 coin cell battery.
Hope this helps
Jan 12, 2015 | Lenovo 3000 J205 9686-A12 Desktop Pc -...
Chek smos errer
You have described you problem incorrectly. I guess the error mess is "CMOS Cheksome error. " I guess.
This messenger comes due to following situations.
1. CMOS battery low. Check for the CMOS battery (most commonly CR2032) power if it is low this message can appear.
2. BIOS has been reset on purpose or by a fault. Set time date and other settings.
3. Motherboard problem. Rarely motherboard will have this issue with CMOS or with the battery powerline making it to lose CMOS Setteings. Change the motherboard or live with it.
Regards
Apr 01, 2014 | Computers & Internet
When i turned on my computer message RTC battery is low or CMOS checksun is inconsistent press f11 key to set date i have tryed f11 and had it pluged in all night still same message.
Means your CMOS battery is flat and will need to be changed, as that keeps the date and time saved at all times if it dead then every time you turn off the computer the date and time will not be saved and have to re-set it. changing the battery will solve this problem. Kronoguy
Jun 29, 2011 | Toshiba Computers & Internet
Every time I turn it on, I have to reset all setting, It will not save setting after it is turned off. I.E clock, and date: some times wireless settings depending on how long it was off. Cmos batterie?
YES. The CMOS battery (complementary metal-oxide semiconductor) is low off charge or dead and needs to be replaced.
The CMOS typically is a battery-powered memory chip in your device that saves information needed at start up (before any software or program will run). If the battery is low of charge or is dead, you will eventually lose your personal settings and even some factory settings. The CMOS battery can be discharged if you have not used your device for long time.
Hope this helps.
Jun 25, 2011 | Sharper Image Literati Reader 16375680042...
How to know if the battery of the motherboard is empty
use multitester to check the battery of the cmos..
set the multitester to DCV 10..
and watch out for the pollarity of the battery..
Mar 18, 2010 | EliteGroup ECS GF6100-M754 Motherboard -...
Low battery alert at start up. must always type
The only battery in a desktop PC is the CMOS battery. This is a 10c sized silver disc that is held in a plastic black clip on the Motherboard. It can be clipped out and easily replaced. they are 3.6v and somewhere like Radio Shack etc. will have them.
Jan 27, 2010 | Dell Dimension 8400 PC Desktop
I have a Dell dimension 9150 which is 2 1/2 years old. Does it have a battery that I need to be concerned about replacing. I remember that used to be a problem with computers but don't know if that is...
Every PC motherboard has a battery. That battery serves two purposes: to feed the configuration memory (also called CMOS) and to feed the real time clock of the computer (the one that show the date and the time).
An indication it is time to change the motherboard battery is receiving one of the following error messages when you turn on your computer: CMOS CHECKSUM FAILURE, CMOS BATTERY STATE LOW, CMOS SYSTEM OPTIONS NOT SET and CMOS TIME AND DATE NOT SET. Another indicator of a low battery is a clock that, after being set, runs well while the computer is on, but shows the wrong time when the computer is turned on the following day (it is late).
Apr 21, 2009 | Dell (2336V) Motherboard
**** RTC battery is low or CMOS checksum is inconsistent **** Press [F1] to set Date/Time
Hello
Please reset cmos to factory defaults.
Then enter the bios setup and configure it and save changes.
Apr 20, 2009 | Computers & Internet
ASUS P5S800-VM Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
