Question about Canon Pixma MP640 All-In-One InkJet Printer
Error code 5.145.55
Scanner is turned off /scanner is disconected
2 Suggested Answers
  • 10 Answers
SOURCE: my scanner has not worked
Follow these steps:
1. Unplug the printer.
2. Uninstall the driver.
3. Re-boot your computer.
4. Then reinstall (from the CD if you still have it)
5. Follow install instructions with printer.
6. Test the printer/scanner/etc.
7. If this doesn't work... go to canon's website and download the most current driver for the printer. then redo these steps using the downloaded driver for step 4.
If this doesn't work, return the printer if you still can.
Posted on Apr 02, 2011
My scanner has not worked since i purchased this printer. My error is as following: CANNOT CMMUNICATE W/SCANNER. cable may be disconected or scanner is turned off. CODE: 2,155,0. PLEASE HELP!!!!
Follow these steps:
Apr 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I have an error of code 5,145,55 what should i do?
Reset the printer, clean and check mechanism of the printer
Jan 10, 2011 | Office Equipment & Supplies
By winodj_d on Nov 23, 2010 the analyze of the car gifs still a p420 error. After replacing the lambda sensors (oxy sensors) and the katalysator. on a chrysler pacifica 2005 fault has been...
CODE PO420 - CATALYTIC EFFICIENCY BELOW NORMAL BANK I POSSIBLE CAUSES - BASE ENGINE PROBLEMS HIGH COOLANT OR ENGINE OIL CONSUMPTION- CATALYTIC CONVERTER DAMAGED OR HAS FAILED - AIR LEAKS IN AT THE EXHAUST MANIFOLD OR EXHAUST PIPES -YOU NEED A CODE SCANNER TO ERASE CODE.
Nov 25, 2010 | Chrysler Pacifica Cars & Trucks
Code:5,145,55
i have an error code: 5,145,55 wg=hat should i do?
Oct 05, 2010 | Canon Office Equipment & Supplies
Code:5,145,55 I cannot scan wirelessly
Installed for USB, need to install for wifi.
Solution:
- Uninstall drivers and utilities
- connect device via wifi to router (should still be)
- install again. Choose in step 10 of installation process option wireless connection.
should work now.
Sep 06, 2010 | Canon Office Equipment & Supplies
How do you reset an error code on a 06 avalanch
Unplug the negative battery, wait few minutes and re-pluged. THis reset the ECU store codes. If the check code turn on again, I suggest scaning OBD codes (autozone) for knowed exactly what fault is there.
Good luck (remember comment and rated this).
Apr 13, 2010 | 2006 Chevrolet Avalanche
Printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Jan 15, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
"scanner is busy" message
Turn the scanner off, disconect from computer, turn on again while its disconnected, let it do its startup routine for a few minutes. When it stops making noises, turn off again. Turn off computer and restart. Connect scanner again to computer and turn it on. Start the software. I'd appreciate if you'd let me know if it helped. Otherwise you might need to open it or send it for repair to Sony. Service contact is here: http://ca.konicaminolta.com/support/contact/sonylist/index.html
jorgemtrevino <at> gmail <dot> com
Dec 24, 2007 | Minolta Dimage Scan Elite 5400 Film...
Error 21550 pixma mp160
Thsi usually happens with canon printers and scanners jsut re-install the driver...I wonder when they will fix it..This happens each time you disconnect the cable and then put it back..
Nov 13, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP640 All-In-One InkJet Printer Logo
358 people viewed this question
old marine
old marine
