Question about Sony Audio Players & Recorders
Left speaker channel sound intimitent
Sometimes the sound goes off on the left speaker, when i increase the volume the sound comes back
  • Rocky Degelman Oct 29, 2012
    The IC is going in it for Left channel
    Genius:
  • 1,212 Answers
It may be as simple as a dirty volume control, Some contact cleaner will remedy that. but it may also be as time consuming as finding a bad solder connection. If it drops out with headphones on, suspect the volume control area and the preamp section of the amp. If it just drops out with the speakers, but not the headphones- look at the connections around the output transistors. If nothing is apparently broken, and solder joints are sound or reflowed with no change, get a can of "component chiller" and spray each output transistor of affected chennel, and the electrolytic capacitors in the finals and driver stages until it corrects and then replace defective part, though i suspect a bad solder joint to be more likely.. .
Posted on Oct 31, 2012
marsrover
  • 682 Answers
SOURCE: scratching sound in speaker conected to left channel
invert the speaker cables if the problem went to right speaker you will find a problem in your left speaker(cable or speaker)-if not you will have a problem in your amp itself.
Posted on Jul 14, 2008
marsrover
  • 682 Answers
SOURCE: problem with philips Powerhouse AW626 music System
try to invert your speakers cables and connect your right speaker cable to left output if the problem still happened you will have a problem in your amp and ask for help from good service center near you-------if the problem disappear you will have a problem in left channel----cable or speaker.
Posted on Aug 02, 2008
SOURCE: Creek 5350SE amplifer left Channel dead
It's the ribbon cable that is likely at fault. There are actually three computer type ribbon cables in the amp. I believe the cable that is responsible for the drop-out of a channel is the widest (longest) of the three, but you really need a tech to look at it and replace the cable. But please note that the new cable may also have defects in manufacture and that it may take some time to order a new cable from Creek. I had a tech solve the problem permanently by removing all three ribbon cables and then hard-wiring the connections together - that is to say, point-to-point wiring. My cost was about $250, but as you can imagine, there is extensive labor involved. Good luck!
Posted on Aug 13, 2009
tech240
  • 169 Answers
SOURCE: losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Posted on Sep 20, 2009
Grubhead
  • 5126 Answers
SOURCE: I have a Sanyo Stereo Amp. Model # JA-660-2. The
Spray it with Servisol Video 40! It's just dirt on the track. You can get it from Maplin (UK) or Radioshack (USA). Or any electronic shop.
Posted on Jan 17, 2010
My 07 avalanche has bose s s intermittent sound on left channel
Sound troubleshooting - Bose
worldwide.bose.com/.../en...tv...sound/page.html?...
Bose CorporationSound troubleshooting. No sound from speaker. Make sure the sound system is turned on and the power indicator is on (solid green). Increase the volume.
Aug 08, 2015 | Cars & Trucks
Very week sound
Definitely need more info - such as type of amplifier or receiver, how many speakers you are running, whether the subwoofer is powered or not.
As a simple test procedure: Disconnect all speakers and plug in a pair of headphones. Get a strong audio signal? Good, move on. No signal or week signal, you have an amplifier issue before the audio even gets to the speakers.
Next: Disconnect all speakers, turn the volume down, and connect one speaker to the left output channel. Slowly increase the volume. If that works, do the same on the right channel. Everything OK? You're putting out enough gain on both channels. Sometimes one channel goes bad. You can still listen to your sound in mono moder, or drive two speakers from the single working output. Not stereo, but dual mono. Move on.
Connect left and right speakers but not the subwoofer. Repeat the test. Whatever is left is probably the problem. If the subwoofer is powered, check the power supply or incoming voltage. If the other speakers are driven off the subwoofer or powered from there, that's likely the problem.
Jul 31, 2015 | Audio Players & Recorders
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
Speaker sound on and off
Check that the wire are not loose going to Speaker.or has a break in it.
Oct 29, 2012 | Car Audio & Video
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
Jul 20, 2012 | Yamaha RX-V530 Receiver
In dolby digital mode i can not get any voice volume. All other sounds are ok
Assuming that you mean Dolby digital 5.1, confirm that you have a center channel properly connected and perform the following;
Using the remote, enter the menu on the receiver and navigate to the selection labeled "LEVEL." Toggle through the selections until you reach the "CENTER CHANNEL". You will be able to use the remote to increase the volume of that channel in .5dB increments.
Feb 01, 2011 | Denon AVR-589 Receiver
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
Dec 11, 2009 | Denon AVR-587
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
The left channel of my stereo goes out sometimes
The most common cause of this is corrosion on the output speaker relay contacts. A simple test can confirm this: When the channel drops out, try turning up the volume. If the channel kicks in again, the relay contacts are the likely problem. The higher volume generates a higher voltage which essentially "jumps the gap" and restores contact.
Keep us posted.
Da n
Apr 26, 2009 | Kenwood Audio Players & Recorders
53 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
