Question about Dream Maker Spas Pool & Spa
What all can be done to maintain spa tub in a good manner?
Please help me by extending your suggestions on this. Thanks in advance.
    Top Expert:
  • Dream Maker ... Master
  • 7,228 Answers
Keep chemical balance PH 7.2 to 7.5 alkalinity to 80 to 120
Posted on Nov 19, 2017
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: breaker on the end of
I have had a few troublesome units over the year that did as you describe due to 'dew' overnight collecting around the tub and the increased moiture sent the motor of the circ pump "over the edge" iinto a grounded state. A leaking pump seal was adding to the problem. Once the seal leak along with the dew got high enough the GFI would sense the grounded condition and trip. Fixing the pump seal and drying/cleaning the motor fixed the problem every time. If you find any other leak sources around the pump you will need to fix them as well.
Posted on Oct 12, 2010
Tub won't heat Message SL
Not much info here but SL could be the mode setting. Typically modes are SLEEP, ECONOMY and STANDARD. Standard maintains your set temp at all times even if it has to turn on outside of normal filtration cycle. Economy only heats during a filtration cycle, and sleep will only heat within 10 degrees of set temp and only in filtration cycle. This cycle is really only useful while going on vacation or other extended periods of non-use. Not sure how to help change modes without knowing what spa pack you have but you should be able to find the owners manual on line with a little research.
Mar 02, 2017 | Pool & Spa
What chemicals do I need in my intex inflatable hot tub
Hi, according to this site How to Treat Your Hot Tub Best Hot Tub for 2014
First check th pH levels with the pH level checker.That is pretty straightforward and should be included in instructions with your pH checker (which may have come with your hot tub)
It's good to do a chlorine shock once you fill the hot tub with water.
So what will you need?
pH tester/pH tester strips
chlorine
And chemicals for balancing ph ... pH+ and pH- which you will surely find in a shop with pools.
Each of this should come with instructions.
Apr 09, 2016 | Intex Pool & Spa
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
How to select hot tub covers?
Also check out Hottubworks.com as they have all patterns for Dream Maker.
Suggest you get a cover which is 2lb density which will last longer and has a doubled wrapped core. The cover will last allot longer than your original and keep more heat in. Here's link http://www.hottubworks.com/SpaCovers/Features.php
Oct 29, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
In econ mode my 1998 spaform hot tub does not appear to heat but it is ok in standard mode.
in the economy mode it will only maintain a temperature so that it will not freeze. Economy mode is mostly for vacation time or for winter if you are not going to be using the hot tub for an extended period of time.
Put it into the standard mode and you will be able to have a HOT tub and will function as it should
US Parts Center
Aug 22, 2011 | Pool & Spa
Filter Pump motor is On, but no Water Circulations.
You have probably pulled the center out of the impeller. Please shut this pump off immediately before you over heat and distort the housing and damage the motor.
You use a paper filter on this device? This has salt water in the tub? or you use salt water as a water treatment?
I think you had your spa running and you turned it off for some reason and immediately turned it back on. If there was ANY pressure in your system, that pressure was running the impeller backwards when you turned the motor back on and that is why the center is pulled out of it.
Of course there may be other reasons for this problem and you will never get anyone to admit to doing this ... but it was evidently done.
I frequently find this problem at work where I maintain three public bodies of water ... till I got rid of the 'pool attendant', that is!
thanks for posting your question at FixYa.com
If you find this response helpful, please vote
thanks
Dec 21, 2009 | Washing Machines
Corrosion on the fins of my heat pump
Do you have something close to it like a hot tub or spa or pool? If so the Chlorine is reacting with the aluminum causing it to corrode.
I suggest moving one or the other if this is the case.
If this helps you please rate me as high as you can If not please post back with an extended detail of your problem. thank you for using fix ya. Good Luck.
Nov 13, 2008 | Hayward Heatpro 100,000 Digi. Thermostat...
Pool & Spa Logo
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
Craig Butler
Craig Butler
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
