Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
How can we choose a spa cover?
I am planning to buy a spa cover as mine is broken by last week. It showed a low performance even under high rate. It will be a great help if anyone of you tell your ideas on buying a good spa cover.
Error message Fault. High Limit , upon attempting to use the heater for the first time this season
either not enough water flowing through heater or low gas pressure to overheat unit replace high limit in stack if not one replace one on bottom white unit with 2 white wires
May 26, 2016 | Jandy LRZ250EN Legacy LRZE Pool & Spa...
Can you buy just the on high and low switch the pumpl
You cannot purchase just the high/low parts for motors. There are wires going from the controls to the high side and the low side of the motor.
Rod
US Parts Center
May 03, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
I have a new jandy pool heater and the heat exchanger leaked after 6 weeks usage. The previous heater lasted 15 years.?..
make sure you keep chemicals in balance ive seen a heat exchange ruined in hours too low PH too low alkalinity too high it will calcify
Sep 12, 2012 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Just had my Hayward Tristar 2-spd pump/motor replaced a month ago. I've been running it on high speed for about 3 weeks because my control pad went out and I couldn't get it to run on low speed. ...
running the pump on high speed will not have caused the problem, they are meant to run 3,450 rpm's continually. It's more than likely a supply power problem like you mentioned. Check GFI's, and breakers to see if anything has tripped.
Jul 26, 2011 | Pool & Spa
When im on the computer the monitor shuts off a box appears saying power saving enabling monitor to shut down in a few seconds and then it restarts
Windows provides the following plans to help you manage your computer's power:
  • Balanced. Offers full performance when you need it and saves power during periods of inactivity. This is the best power plan for most people.
  • Power saver. Saves power by reducing system performance and screen brightness. This plan can help laptop users get the most from a single battery charge.
  • High performance. Maximizes screen brightness and might increase the computer's performance in some circumstances. This plan uses a lot more energy and will reduce the amount of time that a laptop battery lasts between charges.
    Note
    • High performance doesn't appear on the battery meter by default. To turn on High performance, open Power Options by clicking the Start button ?id=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33, and then clicking Control Panel. In the search box, type power options, and then click Power Options. Under Select a power plan, click Show additional plans, and then click High performance.
If these plans don't suit your needs, you can create your own power plan, using one of these plans as a starting point.
Feb 13, 2011 | Gateway 510 S PC Desktop
Graphics are TOO low
If it is to low, or slow refreshing rate when using to play game or when using high end apllication, then that means your graphic card is lacking power due to gpu speed, or under powered gpu memory. Usually onboard graphic card with the motherboard are really low ends. You can buy a graphic card of better performance and installed on your expansion slot. In your case it is a AGP expansion slot for the video card and you will need to buy a AGP video card, nvidia or ati 7,8 series or the ati X1600 seriers + or HD series, the 9 seriess (9600+) are kinda out of dated. don't settle for lower series as they are outdate and under performance as well, all depending on what apllication you need them for, for latest high end games or digital imaging, or superior HD programing, then minus replace the who combo thing.
Jan 23, 2011 | ASUS P5S800-VM SiS 661FX/964 LGA775 DDR...
Hi,im planning to buy samsung as-185usb air conditioner.is it advisable to buy? how do u rate it?
Any air conditioner, please go with 3 Star ratings to 5 Star.Better not to go with 2 star and no star rated. The high rated proves the long life of compressor performance in minimum current (Amps).
Hope, helpful?
Jan 20, 2011 | Heating & Cooling
I have a 2010 viking heritage 2 spa. the owners manual says that for the primary pump, there are low, high, and off settings, but mine only goes from low to high. no matter what setting it is in, the pump...
If you have a timer and it is on a maintenance cycle that will keep it on low, A freeze control that will keep it on under about 38 degrees. If the thermostat is controlling the pump it will keep it running also. If it has a cool down mode to let the heater cool that will keep it running. These are some reasons it will stay on and their may be more. I would turn the thermostat down and if it's cold out run a heater under the cabinet and make sure that no timer is controlling the pump. Set it to low and walk away for half an hour if it won't shut down turn it up to high and back down again. One of these low speeds should be off. Good luck.
Oct 24, 2010 | Heritage Pool and Cover Pump
High speed setting on pump won't work.
might be the starter capacitor or run capacitor
Jul 14, 2009 | Pool & Spa
Paper jam
THE PAPER IS INSIDE BETWEEN THE ROLLERS AND YOU WILL HAVE TO REMOVE THE COVERS OR PAY SOMEONE TO FIX IT FOR YOU.
AS CHEAP A NEW PRINTERS ARE WITH INK AS HIGH AS THEY ARE, YOU CAN BUY A PRINTER CHEAP AT WALMAT,
LAST WEEK WE BOUGHT A NEW CANON FOR 29.99, IF YOU DONTS WANT TO HASSLE WITH IT THAN BUY A NEW PRINTER
Mar 31, 2009 | HP Officejet 4315v All-In-One InkJet...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
