Question about Unitech PT630
Cannot escape command menu
Have rented the pt630 to do some large scale stock-taking after Christmas. Over-zealous colleague pressed something on scanner; now the only thing that comes up is a message saying:
PT360 BIOS V1.91
MEM 2560 KB
>_
Anything we enter comes up as a BAD COMMAND. We've been trying to reach the helpline number but no-one's picking up. As we only have the scanner for the weekend (and it's usually a fairly simple process), we were never sent out a manual.
Can anyone help?
Warning p? why cannot print
When printer resets or gets print que changes. The machine resets to a default 4x6 card stock glossy. Its telling you that your paper size is not correct. Right top corner is menu or settings. You can also command color or grey scale. B/w . The color mode is default also. To conserve ink. Run in grey scale only uses one of your cartridges the bk.
Aug 18, 2015 | Canon PIXMA Office Equipment & Supplies
What the best sentence will i use to ask my boss for unequal salary he gave. my salary is lesser than my colleagues
You need to be very careful in comparing yourself with your colleagues who might be better qualified, more experienced and more senior in your current work place.
If you believe that you have the same attributes as your colleagues, nicely but firmly ask for a 'salary review' based on 'industry going pay scales' (get supporting documentations such as job ads) an/or your current 'higher' duties ... but be prepared to look for another better paid position in another company!
Sep 21, 2011 | Computers & Internet
MESSAGE PT630 BIOS VI.94 MEM 4608 KB WHAT SHOULD I PRESS TO PUT IT ON SCAN MODE? (READY) THANK YOU
Press and hold CMD button. Then, option 8 for settings, option 2 for scanner. Use arrows and enter key to select your preferred settings from there.
Feb 02, 2011 | Unitech PT630 Portable Terminal
Our Genicom Tally printer fails to keep settings. The model type is 6312. What could be the problem?
There may be a number of reasons for the 6312 failing to keep your settings, the first thing to identify would be that you have changed the settings on the printer and then saved these settings. If you do not save the settings to a menu / configuration they will be lost if the printer is powered off or receives a reset command.
Once you have made your settings changes, the settings can be saved in the following way;
Ensure the pritner is OFFLINE
Press Menu
Press Up Arrow until display shows Config Menu
Press Enter
Press Up Arrow until display shows Configurations
Press Enter
Press Up Arrow until display shows Save
Press Enter
Press Up Arrow until the Config Number Or Name appears that you want to save the settings to (Default is Confg 1)
Press Enter
Press Clear, to return to Offline mode.
If you save your settings you can then print a configuration report to see the values that have been saved, this can be done in the following way;
With the printer OFFLINE
Press the Menu key
Press any Arrow key until display shows Config Menu.
Press the Enter key.
Press any Arrow key until display shows Printer.
Press any Arrow key until display shows Report.
Press any Arrow key until display shows All Configs.
Press the Enter key and the configurations will be printed.
This should show your saved settings, try powerign th epritner off and back on again and again print the Congfig report to check the settings are retained.
If you find the settings appear to change when you print to the printer this will be caused by your print job, escape commands in the print job will take presidence over the printer menu settings.
You would need to check the host computer system to see what might be causing the problem; chack page size, fonts, ensure the correct printer driver is used etc on the system.
Jan 26, 2010 | TallyGenicom 6312 Matrix Printer
Power commander mapping problem
Have you tried looking on the power commander website? They have all of the configurations that you are looking for just take a look.
Jul 21, 2009 | Harley Davidson FXD Dyna Super Glide...
Unitech pt630d reset code
That message which your scanner is displaying is the normal and correct mode in stdby, there is no problem with it.
If the scanner says "bad command" is because you are pressing the "enter" (ENT) key without any command selected before.
Bye.
Feb 12, 2009 | Unitech PT630 Portable Terminal
How can I change the LCD contrast on the Unitech PT630? Thanks!
Press the button and hold CMD and then -> to adjust the contrast.
Dec 08, 2008 | Unitech PT630
How can i change language to english
Press menu
press Med cup(arrow down) twice
Press menu
Then use small cup(arrow up) or med cup (arrow down) to scroll through the different languages.
Once you have found english press menu.
Press large cup (escape key)to exit menu.
Done!!
Sep 20, 2008 | Gaggia Titanium Espresso Machine
Unitech PT630 files
What program are you trying to replicate? Is it a third party application? What error you received on the PT630 screen when u run the program.
Dec 30, 2006 | Unitech PT630 Portable Terminal
Unitech PT630 Logo
270 people viewed this question
Top Unitech Computers & Internet Experts
David Payne
David Payne
Are you an Unitech Computer and Internet Expert? Answer questions, earn points and help others
