Question about Panasonic SC-PT875 Region Free 1080p DVD Home Theatre System
Dts surround sound not outputting via optical/digital cable from ps3 blu ray playback through panasonic home theatre system SA-Pt875 (menu and and xmb sounds working fine as well as dolby digital, just no DTS playback when movie is played.) Setup is this: Ps3 video output via hdmi to tv, Optical cable to home theatre receiver.
    Top Expert:
  • Panasonic Master
  • 14,162 Answers
Posted on Jun 27, 2016
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
Aug 24, 2012 | Audio Players & Recorders
DTS Doesn't works with my PS3
there are a few versions of DTS. if you are enabling DTS HD master on the menu for a blu ray disc this only outputs through the HDMI port not optical. This goes with all the new versions of DTS. If it is just DTS 5.1 it should go through. Make sure you have all the latest updates for your PS3. Make sure you are enabling DTS in the PS3 menu for optical out.( i dont own one so i dont know the menu at all) I just want to help. I hope this helps alittle and good luck with this.
Feb 20, 2009 | Panasonic SC-HT920 System
Connection problems
Yes you can by connecting a optical cable from bd35 to your systems optical in put,then select this in put on your sysyem and set sound to prologic2, you will not get HD MASTER or DOLBY TRUE HD audio but will get dolby digital and dts.
Hope this helps.
CABLE GUY.
Jan 05, 2009 | Panasonic SC-HT520 System
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
SC-RT50 Decoding Surround Sound From Aux and Inputs
The other players need to be setup to output digital sound. Assuming you are using a digital or optical audio cable, go into the setup screen of the Blu-Ray or Tivo etc. and select the audio setup screen. Set the audio output to PCM.
Sep 07, 2008 | Panasonic SC-RT50 System
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Panasonic SC-PT875 Region Free 1080p DVD Home Theatre System Logo
113 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
