Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
How to select hot tub covers?
I am in search for a good cover for my hot tub. Can you please let me know what all should I point while choosing one?
    Problem Solver:
  • 9 Answers
Also check out Hottubworks.com as they have all patterns for Dream Maker.
Suggest you get a cover which is 2lb density which will last longer and has a doubled wrapped core. The cover will last allot longer than your original and keep more heat in. Here's link http://www.hottubworks.com/SpaCovers/Features.php
Posted on Oct 29, 2012
2 Suggested Answers
jaylabelle93
  • 64 Answers
SOURCE: Foam in hot tub cover broke
Redwine2 is exactly right you can get new foam inserts but often they are not much cheaper than buying a new hot tub cover. You can go to www.thecoverguy.com for all information on hot tub covers and replacing the foam inserts if you need to.
Posted on Aug 01, 2012
What is the best product to remove ring in hot tub?
SECRET:
Use a a Good Quality Name Brand "Filter Cleaner".
Works great as a surface cleaner for your hot tub.
May 26, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Tip
A New Hot tub cover will lower your Hot Tub Costs
A New hot tub cover will help you run your hot tub at a more efficient level. Lower your energy costs as the new hot tub cover will insulate better. The question is when do you need a new hot tub cover.
The best ways to know if you need a new spa cover or hot tub cover are the following:
  1. The hot tub cover weighs over 100 pounds.
  2. You need more then one person to remove the hot tub cover.
  3. The hot tub cover is ripped and torn past repair.
  4. Faded cracked and just aesthetically ugly.
  5. The seam in the middle is ripped past repair.
Can you fix your hot tub cover? Some things you can fix like rips and tears. You can take the cover to a local seamstress to repair. You can not fix a saturated hot tub cover, it needs to be replaced at that point. New Hot Tub Cover for the Fall and Winter
on Sep 05, 2015 | Home
Tip
Hot Tub - Spring cleaning and Maintenance
Spring is a great time to change the water in your hot tub and clean or replace your hot tub filters. Drain and give your hot tub a good thorough cleaning to rid yourself of the winter season. Make sure that you clean your hot tub cover at the same time both the top and the underside. This will help the hot tub cover to last longer and perform better. Hot Tub Spring Cleaning Tips
on Mar 27, 2015 | Pool & Spa
There is a leak and we can not find it. Any solutions
This may help?
Fill spa to highest level possible.
Heat to 100 degrees or higher.
Then, with your bare hand feel throughout the bottom rim and anywhere else you are able to: see if you can feel "Warm/Hot" water. Any "Cold" water is not the area of the leak, that water has "Travelled" there. The warmer the water, the closer you are to the origin.
Jan 01, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
Is there a good website to buy accessories for my hot tub? steps, cover lifter, etc?
i like the brand litehouse. you can see their spa accessories here:
http://www.litehouse.com/spa-accessories.aspx
Jan 28, 2013 | Pool & Spa
How can we choose a spa cover?
make sure when ordering if it has skirt or no skirt that overhangs edges and if has taper at top for water run off
Oct 29, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
The foam instulation in my hot tub cover broke from heavy water
Pretty hard to repair. If the outer shell is intact, just use it. You may open the cover and take the foam out, duct tape it and reinstall. Other than that, you have to buy a new one. Good luck...Lee
Sep 21, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
The foam in there is available at most insulation or drywall supply houses. It is used for insulating concrete walls, the cover is probably 3 inches thick so you may have to buy 2 sheets to get the thickness you want. The only issue is the cost of the foam may not be much less than a new cover.
Mar 11, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
111 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
