Question about Car Audio & Video
Speaker sound on and off
Sometimes the left channel speaker sound goes off and then on again when i turn the volume up
    Master:
  • 444 Answers
Check that the wire are not loose going to Speaker.or has a break in it.
Posted on Oct 29, 2012
Very week sound
Definitely need more info - such as type of amplifier or receiver, how many speakers you are running, whether the subwoofer is powered or not.
As a simple test procedure: Disconnect all speakers and plug in a pair of headphones. Get a strong audio signal? Good, move on. No signal or week signal, you have an amplifier issue before the audio even gets to the speakers.
Next: Disconnect all speakers, turn the volume down, and connect one speaker to the left output channel. Slowly increase the volume. If that works, do the same on the right channel. Everything OK? You're putting out enough gain on both channels. Sometimes one channel goes bad. You can still listen to your sound in mono moder, or drive two speakers from the single working output. Not stereo, but dual mono. Move on.
Connect left and right speakers but not the subwoofer. Repeat the test. Whatever is left is probably the problem. If the subwoofer is powered, check the power supply or incoming voltage. If the other speakers are driven off the subwoofer or powered from there, that's likely the problem.
Jul 31, 2015 | Audio Players & Recorders
Left speaker channel sound intimitent
It may be as simple as a dirty volume control, Some contact cleaner will remedy that. but it may also be as time consuming as finding a bad solder connection. If it drops out with headphones on, suspect the volume control area and the preamp section of the amp. If it just drops out with the speakers, but not the headphones- look at the connections around the output transistors. If nothing is apparently broken, and solder joints are sound or reflowed with no change, get a can of "component chiller" and spray each output transistor of affected chennel, and the electrolytic capacitors in the finals and driver stages until it corrects and then replace defective part, though i suspect a bad solder joint to be more likely.. .
Oct 29, 2012 | Sony Audio Players & Recorders
The sound in the left speaker goes on and off on rough road. turn the volume up to max it works. Turn down 2-3 and no sound
IS A LOOSE WIRE CONNECTION TO THIS SPEAKER ---- WHEN ON FULL VOLUME THE HIGHER CURRENT COMING TO THE SPEAKER KEEPS IT PLAYING .......
CHECK THE CONNECTION ON THE BACK OF THE SPEAKER ---- MAYBE UNHOOK AND RECONNECT AGAIN ......... IF NOTHING CHECK THIS SPEAKER CONNECTION AT THE
STEREO REAR .............. YOU WILL FIX THIS
Jun 29, 2011 | Car Audio & Video
Speakers shorting out
at medium volume push the speaker cone with your hand ( be gentile and push it several times) if the speaker make sound again then the problem is the spaeker and must be replaced , if its possible switch the speakers from one channel to the other channel to see if the problem is the speaker or the output channel
Feb 26, 2010 | Audio Players & Recorders
Losing the right channel
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
Sep 17, 2009 | NAD C370 2-Channel Amplifier
The left channel of my stereo goes out sometimes
The most common cause of this is corrosion on the output speaker relay contacts. A simple test can confirm this: When the channel drops out, try turning up the volume. If the channel kicks in again, the relay contacts are the likely problem. The higher volume generates a higher voltage which essentially "jumps the gap" and restores contact.
Keep us posted.
Da n
Apr 26, 2009 | Kenwood Audio Players & Recorders
Sound through one channel
Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
Jun 14, 2008 | NAD C372 Amplifier
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
