Question about Maytag Dryers
Dryer won't heat
  • 3 Answers
It could be one of three things.
1.) Your lint filter has over-clogged at one point and their is lint under the trap suffocating your dryer.
2.) Check at both ends of your dryer's silver hose on the back side. Those are known for clogging over time when lint catches randomly.
3.) The most expensive issue: Your heating element probably went eiout. Its not super hard to change, however it does take some time. If you call an appliance repair person, it may be $150-250 to have them do it.
Hope that helps!
Posted on Oct 29, 2012
    Prodigy:
    An expert who has answered 500 questions.
  • 666 Answers
Odds are the Heating element is out. Only repair is to replace it.
Replaced coils & igniter but dryer won't heat. Tested all thermostats and they read good. Can't see if the igniter is glowing or not.
check psu to ignitor and the main burner valve sets and resets
you can do this manualy by removing the thermocouple and testing the burners does it try to strike??? and doesnt burn or does the burner try to come on then go out if it wont strike perhaps the door catch isnt right you dont give a make model etc details so its hard to even guess,,,?
Dec 20, 2014 | Dryers
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
My dryer is tumbling & blowing & all the cycles seem to work but it won't heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Frigidaire AEQ8000FG Dryer
Whirlpool supreme lhi 5801 won't heat. The coil turns red but won't ignite anything. I'm pretty sure the gas is on. I don't know what else it could be...
heatman101
Sep 03, 2011 | Dryers
Won't heat up
If it won't heat it will be either the heating element or the thermostat or the control board.
Aug 28, 2011 | Whirlpool GEW9250 Electric Dryer
The dryer won't stop running & will not heat
heatman101
Jul 28, 2011 | Frigidaire AEQ6000ES Electric Dryer
Dryer won't heat up & keeps running after cycle.
heatman101
Jul 03, 2011 | Dryers
Maytag MDG8057 dryer won't heat. I unplugged the dryer to use the outlet for something else, plugged it back in, and now it won't heat. Any connection to unplugging it? If not, potential...
Did yall move the dryer? The ignitor is very brittle. Moving a gas dryer sometimes breaks an ignitor with a little age on it.themobilian_2344.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2011 | Maytag Dryers
What to Do If a Dryer Won't Heat? Brand name Inglis, It's only 2yrs old, While I'm using stop for a while then when I start again the timer is done my clothes is not dry & it's cold. We...
If yourdryer is not heating, check your dryer's venting. First thing to check is to see if you aregetting air flow to the outside through your vent hood. Next, check your voltage to see if you aregetting 220 volts to your outlet. Youcan do this by taking a volt meter set at 250 volts. Take the red leg of the volt meter to the oneside and the black leg to the other side. If the volt reader reads 220 then you are getting the propervoltage. Finally, if you are getting 220volts then it is your dryer heating elements. On a 220 volt for the dryer one leg is for the motor and leg is for theelement. If you are getting 220 volt thenit is your heating elements that are bad.
May 11, 2011 | Dryers
Dryers Logo
500 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
