Question about Poulan PP4218AV 18" Chain Saw
Chain slips off bar
On a Poulan 18" chainsaw, the chain keeps slipping off the bar. Any ideas as to what the problem is?
  • 231 Answers
I would suggest adjusting the tension and cleaning and debris along the chain path (guide bar).
Here's the manual for Poulan PP4218AV =>
http://72.3.225.179/manuals/165555e.pdf
Look at page 6-7 for instructions to adjust the chain tension and page 16 for cleaning the guide bar.
Here's the link to other Poulan Products =>
http://www.poulanpro.com/poulanpro/manualSearchPrepare.do
Posted on Jan 03, 2009
2 Suggested Answers
  • 4088 Answers
SOURCE: I have a Poulan 18
Make sure the chain brake is off (pull it toward you), then remove the bar mounting nut(s)/bolt(s) and the remove the side cover, bar, and chain. Clean the oil passages in the rear of the bar including two small passages that run from the larger holes out to the chain groove on each side. Clean the entire chain groove and make sure the end sprocket turns freely and is well oiled. Clean the engine face where the bar fits, then start the engine. Oil should ooze out of a small port in the engine case. If ok, then lay out the chain so that it can be inspected for bent links, dry/sticking joints, or missing/badly worn drive teeth. Inspect the sprocket on the clutch outer drum component for wear or damaged teeth. Make sure the pitch of the chain teeth match those of the drive sprocket (is this a new chain?). Check the hub bearing of the clutch drum for obvious wear. If all looks good, fit the chain around the clutch sprocket, then slip the bar into the the engine mounting space and work the chain over the entire bar. When setting the outer cover, make sure the adjuster tang fits into the related bar hole, then attach the clamp nut(s)/bolt(s), run up finger tight. Use the adjuster to set the chain tension--it should just pull the lower part of the chain up to the bar plus a little more. Check that you can move the chain by hand without any binding, then tighten the clamp bolts/nuts firmly. Recheck that the chain is properly tensioned. If not, re-loosen the clamp fasteners and re-tension the chain. When the clamp fasteners are tight, the tension must be rechecked. Hope this long-winded response helps!
Posted on May 14, 2010
18" chain keeps slipping while trying to cut oleanders, Is there some way to make the chain more stable?
You need to adjust your bar & chain tension as described in your user manual. Here is the location if you have misplaced: https://images.worx.com/en-us/manuals/WG300%20WG303%20WG304.pdf.
Basically you will take the "large knob" cover off, tighten the bar tension and put the cover back on. This will provide you with additional adjustment tension as needed.
Mar 23, 2015 | Worx WG304 - 18" Electric Chainsaw
How do you change the blade
Remove the cover by taking off the nuts that allow you to adjust the chain and push the bar all the way back then remove the chain by slipping it off the bar and make sure you put the new one on the same way the old one was so the cutters are facing the right way.Good luck.
Sep 11, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The blade keeps slipping off after a couple of minutes of use, the tension is as required. Why does it keep coming off?
Hi luvmylife63.
If you have the proper tension on the chain against the bar and the chain is coming loose right away then you need to replace your chain and/or the bar for your chainsaw.
Please take time to rate me
Sep 08, 2011 | Poulan 14" Chainsaw
I have a 14" Poulan
Take off nut, remove bar and chain, turn adjusting screw counter clockwise, replace bar and chain tighten screw, replace nut.
Aug 31, 2011 | Poulan 14" Chainsaw
I can not keep the chain on. I replaced the bar and chain. It work fine for about 2 hours. Then the chain came off and would not stay on.
If there is no damage to the chain or bar (shouldn't be any if you replaced them), then there seems to be some other possibilities:
1) The sprocket, that transfers power from the motor or engine to the chain, could be damaged so that it does not keep the chain in position
2) The bar is no longer perpendicular to the sprocket and housing for the motor/engine. If the bar is at an angle then the spinning forces would tend to slide the chain out of the slot in the bar.
3) The tension on the bar is not being maintained so that it slips out of the bar slot. You need to monitor this tension as you are working because the forces on the chain an bar tend to push the bar back into the housing, loosening the chain and making it susceptible to slippage.
Jul 26, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Purchased like new PP4218 from local, bought for his son, after one tree, son lost interest. No manual with saw. What chain and bar do I buy as replacements? He replaced chain, not sure it is correct...
it's an 18 " poulan bar and chain...just a standard bar and chain for poulan...most of the aftermarket brands have a cross reference that will give you an idea on which to use
Jan 23, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan 18" chainsaw. Dispite my best efforts to tighten the chain, it keeps slipping off of the bar. I can use it for about 30 seconds, then the chain slips off.
May 13, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain Slipping
Your chain would have to be incredibly loose to slip the sprocket. Enough that it would come off the bar before jumping the teeth on the rear sprocket. Highly unlikely.
Jan 01, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Apr 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan PP4218AV 18" Chain Saw Logo
339 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
