Question about Yamaha Emx5016cf S115v PA System
If i replace my yamaha crossover capacitor, what will be the consequences
The capacitor blew and i think of replacing it
    Sergeant:
  • 238 Answers
The capacitor determines the cutoff frequency of the filter used to either block or pass frequencies above or below the intended design point. Generally, electrolytic capacitors are used for this, due to their capacity for a given size. electrolytic capacitors are manufactured with two foil plates separated by a gauze soaked in electrolyte compound. This electrolyte compound forms a one molecule thick insulation layer. If this electrolyte dries up, the cap will tend to fail, either short or open, usually short. Because the insulation so thn, it is very much affected by the applied voltage (usually DC). Most electrolytic capacitors are used to block DC. these capacitors are usually pretty sensitive to the applied voltage. Most electrolytic capacitors have a WVDC rating, which stands for Woirking Voltage Direct Current. The higher the WVDC rating, the largewr the capacitor for a given capacitance. Also, these capacitors have a very wide tolerance because of this. Typically, this tolerance is +10%/-80%. This rating would indicate that at close to the WVDC rating, the capacitor will be within 10% of its rating. If the capacitor is used in a circuit where the WVDC rating is much higher than the circuit voltage, their will not be enough bias voltage to form the one molecule thick dielectric (insulation) needed for the rated capacitance. So, if the capacitor is rated for 100WVDC and is used in a circuit that only has 40 volts, the effective capacitance will be much lower, and therefor, the crossover frequency would be affected. If the crossover filter is a high pass, then you would risk damage by allowing too much low frequency content to get to the mid/high frequency driver(s). For a low pass configuration, too much high frequency material would get to the woofer, which might affect imaging, but should not damage the driver. Also, electrolytic capacitors come in many varieties. Almost all of them are polarized, meaning that the terminals are marked plus and minus. Capacitors for crossovers are not typically polarized. Here is a link to some non polarized electrolytic caps:
http://www.parts-express.com/term/crossover-caps?c=293,1385
Most audio enthusiasts prefer the sound of polypropylene, polycarbonate or polystyrene capacitors over aluminum electrolytic caps, which also have the advantage of not drying out over time, so they last longer. Also, aluminum electrolytics tend to fail if they do not have a bias voltage applied for a long time. Here is a link to some film cpas for crossovers:
http://www.parts-express.com/term/crossover-caps?c=294,1382
Posted on Oct 31, 2012
    New Friend:
Important is to replace old one with the same type .It means if this was MKT type then you should replace it with MKT one.If you use MKP instead of MKT you might get some more information coming from mid/high speaker but in the same time you will get unpleasant sound and you will not enjoy your music any more like before.Not only that ,you will discover that every MKT or MKP capacitor sounds different.I went through this game and I know it...I suggest you buy 4,5 capacitors of the same value but different brands and just find the best sounding one.The same is with electrolytic --- with some you get more loud bass,with other more precision in bass area.I would suggest for MKT/MKP Visaton capacitors - warm sounding and very clear,great resolution and space and not expensive - and electrolytic Visaton, Mundorf or F&T brands
Posted on Jul 30, 2017
I have 2 peavey sp2 bx well I was pushing them really hard and blew the black widows. Now I have got a replacement and hooked it up and still no sound out of them. I do have the horns working but they...
The lamp bulb fusing is just on the horns. Check the Black Widows individually with an ohm meter for continuity. If the speakers themselves test OK, you most likely blew the crossovers. Peavey service (877-732-8391) can rebuild most of therir crossovers in house and they generally are cheaper to fix than replace.
Nov 02, 2014 | Music
Not working anymore after I plugged in I have heard some electric noise.
Wild guess but if not powering up, possible that fuse blew (if no external, then there's often one on the power board), or something blew in power supply...check for blown filter capacitors (the larger ones, for leaking, or blown/bulging tops), burnt resistor, or bad diodes.
Aug 28, 2014 | Yamaha HS50M Active Studio Monitor (Pair)
My crossover on Behringer speaker cab ba-115 (15" bass driver plus tweeter) is bad. Does anyone have the schematic before I tear it apart?
There is very little to an inspeaker crossover that could go bad unless it was SEVERELY overdriven. I recommend checking the speaker individually on a wire from a stereo or something powered to verify this. A crossover is nothing more than a capacitor (high cutoff) and an inductor.(low cutoff). The 600 watts rating of the cabinet is an RMS rating, meaning, .707 actual peak value free of distortion. This means that you can only drive it about 71% of that without distorting or damaging it. You said, "very little signal gets to the speaker", which sounds like "very low volume" meaning, magnet stuck, speaker not moving much, meaning warped voice coil. Check that the speaker will move back and forth with your hand freely without interference or scratchy noise. If it doesn't, the voice coil is warped and the speaker needs to be reconed or replaced.
Mar 12, 2013 | Music
Used wrong power supply
If it released it's majic smoke- likely an electrolytic blew out. Easy to replace those. It may just have been all that blew.
If something else blew, it may have been a diode, especially zener diodes. But I would start at the Capacitor that blew. I would replace the other electrolytics just to make sure no future problem developed.
Apr 01, 2012 | MXR Phase 90 Pedal
I need to find SOME kind of adequate replacement tweeter or dome or horn for a Yamaha MS150 powered speaker. (used for instruments or PA) The only specs i have are: The back of the magnet reads...
That is a very wide range cone type (oval) type tweeter that probably covers from around 2500 Hz up to 20KHz. You will probably NOT be satisfied with generic speaker... this one is special for sure. Try calling http://www.speakerrepair.com/ocsdiaphragms.html and see if you can get it reconed. Most speakers that are cheap will NOT take the power that the amp will deliver.
Jul 04, 2011 | Yamaha Music
Ran too much power through the speakers and I think I fried the crossovers. Can the crossover be replaced?
This makes little sense... these are bi-amped speakers meaning the crossover is an electronic LOW LEVEL filter network. You can send LINE LEVEL signals to these (never the output of a power amplifier) and not damage the crossover electronics. You would normally connect the balanced line-level output of a mixer into these.
If you have connected a power amp into this by mistake, you likely blew the input circuit. You will have to have the circuitry replaced.
Very important is to connect ALL interconnected equipment to the same power source or receptacle. Powering speakers from one end of a venue and the mixer from the other end wall receptacles is a good way to blow circuitry due to ground bounce in buildings.
Give us more information of how you connected this AND also the symptoms... unless you are into electronics, self diagnosis of the problem may lead you astray as well as the technicians who fix it.
Mar 26, 2011 | Harbinger HP215 Powered Loudspeaker
I just replaced the fuse with a lesser fuse now the amp just hums. The pots are all on low and it does this with or without a instrument plugged in
This is likely a power supply problem such as a bad filter capacitor. If the fuse blew before, probably one of the rectifiers blew due to a shorted capacitor followed by one or more diodes failing.
Take unit in for repair unless you are adept at electronics.
Dec 01, 2010 | Marshall Amplification Marshall AS100D 2x8...
Has anybody ever replaced an entire crossover assembly (circuit board) in a Alesis Monitor One? Specifically, does the woofer need to come out, and if so, how?
Look here:
http://www.instrumentalparts.com/crossover-pcb-board-for-alesis-monitor-one--mk-1-and-m.html
and here: http://ep.yimg.com/ca/I/yhst-15436568105612_2091_46855693
See that 8.2 mfd bi-polar and one of those white ceramic cased resistors???. Those parts feed your tweeter... One of them is bad. You can buy the board for $30 or spend a couple bucks for those parts.
http://www.mouser.com/ProductDetail/Xicon/140-NPAL100V47-RC/?qs=sGAEpiMZZMtZ1n0r9vR22WuTsnx9Abs03070dCRY8QE%3d
http://www.mouser.com/ProductDetail/Xicon/140-NPAL100V33-RC/?qs=sGAEpiMZZMtZ1n0r9vR22UhSjrTM10DE0iKGiddcDi0%3d
Put one each of the above two capacitors in parallel to make 8 mfd to replace the 8.2 mfd and it will work fine. They only cost 74 cents each. You can find the resistors as well from Mouser.com.
IF YOUR crossover is potted in a hard material, that probablly destroyed the caps. The caps would have to be encased in a foam before hard potting as the shrinkage of the potting material would crush the caps a bit and cause failure.
Feb 02, 2010 | Music
Peavey SP 2G has a burnt ceramic capacitor in crossover
Ive been through this. Although it certainly appears to be a ceramic capacitor, its actually called a polyswitch. .65 amp. Parts express carries them. Part no. 071-256.
Mar 28, 2009 | Music
Yamaha Emx5016cf  S115v PA System Logo
228 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
