Acer Aspire 3000  PC Notebook
Problem for Acer Aspire 3000 (AS3004WLCI) PC Notebook
Acer 1642 freezes and will not power down unless battery is remov
By dbrown3800 on Jan 03, 2009
Acer 1642 freezes and will not shut off with switch unless you remove battery. Operates perfectly if using AC power with battery removed. Is this a battery or M/B issue?
Comments:
Jan 03, 2009
- Sorry, should have included that HD has been formatted and clean reload with XP, McAfee and Windows Defender. You can reproduce the condition where notebook freezes, keyboard does not work, will not power off unless battery is removed, by simply installing battery and waiting a few minutes.
Jan 03, 2009
- The problem originally started 2 weeks ago and it will also freeze while initially installing XP.
Jan 03, 2009
- I deleted the partition before formatting....I have also used a new HD just to rule out the HD
Same Problem
Jan 04, 2009
-   It is not a virus or other software issue! I have spent days trying to figure this out. I've completely reloaded all software and within an hour the same problem resurfaces. I believe it is overheating and may have done permanent damage. My unit is four years old - time to buy a new one. -   Guest
Solution #1
posted on Jan 03, 2009
Somewhat Helpful)
gymowner
Rank: Wiz  Acer Expert
Rating: 85%, 233 votes
sounds like a virus or malware, try this, go to spybot, search and destroy and download thier free program, also AVG. com, also free, and run them both in safe mode, also defrag your hard drive, start,programs, accesories, system tools, defrag, it may run several hours, let it a lone, first spybot, then avg, then defrag
Comments:
Jan 03, 2009
- I hate defender and I disable it and run a different program Adware Pro and spybot, instead of defender, defender has been the cause of problems on more than 1 occasion. Did the newlly formatted drive run after installation or has it been a problem from the start, if it has bee a problem from the begining, it sounds like a driver issue, what motherboard are you running, and do you have the right motherboard, sats, etc, I used Driver genius available here,http://www.hashhu.com/, you would have to join the site "fof free" then could have access to the software mentioned, I know that site well and have been on it for a dozen years, i't's up to you weather you want to pay for a driver checking program that you will likelly only use once or twice, but I am a tech and it still found 25 driver updates in my SLI machine. Sli runs dual 7900gt's. So it's up to you I can tell you that I never got any infection of any kind from anything on that site, good luck, and if it works for you please all I ask is that you rate it higher, it affects the way we get compensated, thanks, and I think the driver thing is what it is
Jan 03, 2009
- Ok, see now we are getting someware, if we need to do this one line at a time ,i'm here, First - Did you fdisk or formatt the drive before the install?
Jan 04, 2009
- There is one thing left to try, can you get to the motherboard, if so, then jump the cmos and pop out the battery for 5 minutes, if after you put it back together it still does the same thing, then it is something internal with the board, also if you still are under warranty with it. Then don't go any farther, as taking it apart will void and warranty yo may have. I am really stumped on this, other than a real bad trojen that came along for the ride on the lats format. Just so you know, and you sound like you know more than most, unless you fdisk a drive I have seen an infected drive formatted and still have the infection.The only way to really get it out is to FDSK it. But try the cmos thing first. If you were local I could tell with a couple of diagnostic programs I have, but that is the only problem with doing repairs through a website. I fixed a couple of fellas laptops last week and needed to have them restart to change settings, and I didn't realize that once they were out of the cue, I wasn't able to get them back, until I searched through the entire cue, Duh
Was this helpful?
Yes
No
Solution #2
posted on Apr 18, 2009
Not Rated)
os_db
Rank: Apprentice
Rating: 0%, 0 votes
yep me too - exactly the same thing on aspire 1642 wlmi. problem was battery. tried replacing hard drive, new drivers, HOURS of head scratching time (& visits to two computer 'specialists' !) before I did more research on web & found people with same symptoms and realised problem is battery. Pulled it out and everything works fine.
Battery over 2 years old and not very good to start with I think.. .going for an 8cell now and hope all will be well !!
Was this helpful?
Yes
No
Solution #3
posted on Mar 21, 2009
Not Rated)
sparky300
Rank: Apprentice
Rating: 0%, 0 votes
I had exactly the same problem with shutting down.  Eventually I discovered the problem was the battery.  Remove the battery and it will work fine on the mains supply.  Get a new battery and replace for about £50 if you wish to use remotely.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 3000 PC Notebook
Questions and Unsolved Problems for Acer Aspire 3000 PC Notebook
Do you recommend Acer Aspire 3000 (AS3004WLCI) PC Notebook?
Answer
Answer
When I open Internet - it will show modem operating, then it will say not operating and it... (More)
Answer
i have acer aspire 3000 notebook. i have switching off problems with that before. one of ur expert... (More)
Answer
i have acer aspire 3000 notebook. i had problem that it was switching off randomly so one of ur... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 3000 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
