Question about Panasonic VIERA TX-26LXD80 26 in. HD-Ready LCD TV
TV will not re-tune in same order as other tv's, RTE channels come up 1st
I re-tuned several times and the RTE channels RTE 1 Channel, 1 RTE 2 Channel 2 etc. BBC 1 Channel 806, UTV Channel 800 other channels are all over the place. What do I need to do to get them in UK standard order? Thank you
  • 61 Answers
SOURCE: 1 channel only has no audio.
I believe you have cable box right?
Most of the cases if you are getting audio except channel 11,it could be a cable box problem.you can swap the box to another tv and check..
Good luck
Dals123
Posted on Oct 09, 2008
dave1645
  • 834 Answers
SOURCE: I have retuned my Panasonic HD TV as per your
both of those channels are in anolog, so on todays tvs they are going to look that way, sorry , something you have to live with if the cable company puts them on a digital channel they will look better but not HD quality
Posted on Sep 30, 2009
SOURCE: will not store bbc1 dvb channel
I have contacted Panasonic, they are aware of the problem and will post you an update card to correct the fault.
Posted on Oct 27, 2009
  • 610 Answers
SOURCE: r-tune button doesn't work. defaults to video mode after turn off
the mounting screws into the tv may be too long and short out a communication cable. remove all mounting hardware and see if it still has this problem.
Posted on Dec 02, 2009
SOURCE: Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Posted on Feb 20, 2010
Tuning new tv channels
You can't just tune the new channels on most Tv You have to tune the whole set, go to settings select D T V and ok. If you have done this and still have missing channels the signal me weak, you may have to buy a high gain aerial.
Mar 03, 2016 | Televison & Video
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
My samsung ps42c91hdx/xsa tv wont tune in the high def channel 10. the tv can't find it. My sons tvs are picking it up so it cant be the signal.
go to MENU, SETUP,
There you can reset to factory settings. After you set the clock and date, it will ask to scan for all active channels and it will block out the channels it does not find a signal for. Let it complete this task (20 minutes). It asks you for the type of signal but just leave the STD setting for both options before starting the channel finding routine.
When complete, go to channel 10 to see what show is on (low def version). then click down to channel 2 and then push the channel down button several times again to try and find the HD version of that show. (HD channels are high-number channels that are easiest to get to by scrolling below channel 2. Most will have a hyphan in the channel name (e.g. 93-2; 94-1, 94-2, ...).
If your TV goes directly to a 2-digit channel, they you do not have an HD tuner in your set. I doubt that is true so I think you will find what you need.
Let me know if it doesn't work.
May 06, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
Iv tuned in a new dgital tv, but channel 1 and 2 dont tune it, programs start a 3, if u go backwards, its channel 805 i think press the remote button to analauge and u get channel 1 and 2 but not good...
If you've got a digital box from your cable provider, your tv most likely needs to be on channel 3. At that point you would use the remote that came with the digital box to change the channel. (in other words, your tv would always stay on channel 3)
Mar 09, 2011 | Televison & Video
Hi my lg lcd model no 42LB9DE works fine apart from 1 tv channel has perfect pic but no sounds have re-tuned tv many times to no avail... any ideas ? Tv antenna is is proper working order only 1 channel i...
by reading your problem the main thing is that your tuner of the tv is faulty or it can not tune the specific frequancy of the channel and its audio frequency just replace your tuner card
Feb 16, 2011 | LG Televison & Video
No channel 3, the tv goes from channel 2 to 4, can't use the cable box
Two options...
1. Connect the Cable Box via RCA cables (Yellow/Red/White) or Component cable if you have a HD cable box and select the appropriate input on the TV to view your programs. This will provide the best picture quality as well.
2. Make sure the cable box is on. Using the original TV remote type in the channel 03 and if this tunes to the channel then go to the TV menu and then go to Set up and then select add/erase and select add.
If typing 03 did not tune in channel 3 then using the TV remote select menu then go to set up and then make sure TV / Cable is set to cable then on the cable box press the channel button a couple of times and then select auto program on the tv.
Jan 03, 2010 | Toshiba 27AF44 27" TV
How do I tape onto a vhs from analog tv with converter box?
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
Jan 02, 2010 | Mitsubishi VS-55707 TV
Please advise of NTL requencies in Dublin
The list is
1 Adult chan 355.500
2 Animal planet 299.000
3 At the races 347.500
4 BBC world 291.000
5 Bbc 1 347.500
6 Bbc 2 347.500
7 Bbc 3 363.500
8 Bbc 4 363.500
9 Bbc news 24 363.500
10 Biography 339.500
11 Bloomberg 371.500
12 Boomerang 315.000
13 Bravo 339.500
14 Bravo + 1 402.000
15 Bubble hits 371.500
16 Buzz Tv 315.000
17 Cartoon network 315.000
18 Cbbc 363.500
19 Cbeebies 363.500
20 Celtic tv 418.250
21 Chan 4 347.500
22 Channel 6 355.500
23 Chelsea TV 394.000
24 City channel 291.000
25 Cnbc 291.000
26 Cnn 315.000
27 Dave 291.000
28 DC TV Pilot 371.500
29 Dc tv pilot 371.500
30 Disc home & health 402.000
31 Disc Knowledge 299.000
32 Disc real time 299.000
33 Disc turbo 402.000
34 Discovery 299.000
35 Discovery chan + 1 394.000
36 Discovery science 394.000
37 Disney channel 291.000
38 Disney Cinemagic 291.000
39 Disney cinemagic + 1 291.000
40 E 315.000
41 E4 339.500
42 E4 + 1 355.500
43 Euronews 371.500
44 Euronews deu 371.500
45 Euronews esp 371.500
46 Euronews fra 371.500
47 Euronews ita 371.500
48 Euronews prt 371.500
49 Euronews rus 371.500
50 Eurosport 299.000
51 Ewtn 347.500
52 Extreme sports 323.000
53 Fashion 394.000
54 Film 4 355.500
55 Film 4 + 1 355.500
56 Hallmark 315.000
57 History 339.500
58 Kerrang 394.000
59 Kiss 394.000
60 Liverpool TV 418.250
61 Living 339.500
62 Living tv + 1 402.000
63 Magic 394.000
64 Mgm movies 363.500
65 More 4 355.500
66 More 4 + 1 371.500
67 Mtv 363.500
68 Mtv 2 418.250
69 Mtv base 394.000
70 Mtv dance 363.500
71 Mtv hits 307.000
72 MTV R 418.250
73 MUTV 299.000
74 Nasn 363.500
75 National geo wild 371.500
76 National geographic 307.000
77 Nick junior 307.000
78 Nick replay 402.000
79 Nick toons 402.000
80 Nickelodeon 363.500
81 Paramount 2 323.000
82 Paramount comedy 2 339.500
83 Performance 347.500
84 Playboy 347.500
85 Playhouse Disney 291.000
86 PPV channel 299.000
87 Q 394.000
88 Qvc 371.500
89 Racing uk 402.000
90 Reality tv 355.500
91 Rte 1 339.500
92 Rte 2 339.500
93 Rte 2 the den 355.500
94 Sci fi 371.500
95 Setanta golf 307.000
96 Setanta Ireland 291.000
97 Setanta sports 1 307.000
98 Setanta sports 2 371.500
99 Setanta Sports News 355.500
100 Sky 1 347.500
101 Sky 2 347.500
102 Sky action 323.000
103 Sky classics 323.000
104 Sky comedy 323.000
105 Sky drama 323.000
106 Sky family 323.000
107 Sky indie 323.000
108 Sky modern greats 307.000
109 Sky news 323.000
110 Sky Premier 307.000
111 Sky Premier + 1 307.000
112 Sky sci fi horror 323.000
113 Sky sports 315.000
114 Sky sports 2 355.500
115 Sky sports 3 355.500
116 Sky sports extra 307.000
117 Sky sports news 315.000
118 Smash hits 394.000
119 Tcm 299.000
120 Tg 4 339.500
121 The box 394.000
122 The god channel 418.250
123 The hits 418.250
124 The music factory 363.500
125 Toonami(Toon Too) 315.000
126 Travel and adventure 299.000
127 Tv 3 339.500
128 Tv x 402.000
129 Tv5 291.000
130 Uk tv drama 371.500
131 Uk tv gold 315.000
132 Uk tv gold + 1 402.000
133 Utv 347.500
134 Vh1 363.500
135 Vh1 classic 418.250
136 Virgin 1 299.000
137 Zee tv 402.000
Thanks.
Apr 28, 2009 | Televison & Video
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Panasonic VIERA TX-26LXD80 26 in. HD-Ready LCD TV Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
