Question about NetGear RangeMax NEXT WNR834B Wireless Router
How to install netgear wnr834b without cd
I can't connect to my isp
    Problem Solver:
  • 7 Answers
It depends on the ISP:
If it's DSL (verizon, att, centurylink, etc)
then you will need dsl login and password credentials. (PPPoE or PPPoA)
some others dont require it (DHCP) so you need to call and ask themt o confirm these.
you might also want to ask them about the ADSL settings: Multiplexng Method, VPI and VCI numbers. This will be very helpful.
For CABLE connections (comcast, time warner, etc)
it should be automatic. but if not try to search for MacSpoofing.
http://kb.netgear.com/app/answers/detail/a_id/1086
Posted on Dec 18, 2012
leethedeuce
  • 4472 Answers
SOURCE: how to install if i don't have the installation cd of the router?
Here is a link to the setup manual. If you follow that step by step it is a piece of cake. If you still need help do not hesitate to ask and I will then walk you through it.
http://static.tigerdirect.com/pdf/netgear-WNR834B-manual.pdf
enjoy,
Lee
Posted on Jun 12, 2008
JonoRob
SOURCE: how to install if i don't have the installation cd?
Yoiu can download the online manual @ http://documentation.netgear.com/wnr834b/enu/202-10171-01/index.htm
I'd also recommend you download the updated firmwire located here:
http://kbserver.netgear.com/products/wnr834bv1.asp
Hope this helps.
Posted on Sep 19, 2008
cruton
  • 11 Answers
SOURCE: how to install a wireless router without cd
You can download the device drivers from NetGears own website @ http://kbserver.netgear.com/products/WGT624.asp you will need to select the EXACT model( version you have - this can be found on the stamp underneath the router that has all those barcodes on) and download the latest drivers for yours. by doing this it will trigger 1 of 2 responses:
1. You have the latest version, no update is needed
2. You must setup your device before updating drivers. to do this please select OK
1 - Will trigger an auto setup of the device.
2 - Will take you through the setup wizard itself
which depends on how your router was shipped. If you have brought the router 2nd hand then you can obtain a new setup disc free of charge via the same site if neither of the above work.
For future ref: PLEASE INCLUDE YOUR 'FULL' ROUTER INFO-Different models of the same router can work quite differently and you may not get a best fix without it
Best Regards
Cruton
Posted on Feb 25, 2009
redhaze89
  • 854 Answers
SOURCE: wireless router
Here are some troubleshooting steps that I suggest you try: 1. Check physical connections. a. Connect the modem to the Internet port of the router. The Internet ?i? LED on the front of the router should light up. b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up. 2. Access the router's web-based utility. a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password". Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default. To reset the router: a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in. 3. Configure the router. If your Internet Service Provider is using a cable connection, please follow the steps below: a. Click on Basic Settings under Setup tab. b. Select No for Does Your Internet Connection Require A Login?. c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button. If your Internet Service Provider is using a DSL connection, please follow the steps below: a. Click on Basic Settings. b. Select Yes for Does Your Internet Connection Require A Login?. c. Select Other on the Internet Service Provider drop down box. d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply. 4. Configure the wireless settings. a. Click on the Wireless Settings under Setup. b. Change the SSID to any unique name. c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy). d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit". e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number. Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection. f. Click Apply button to save the changes. g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle. 5. Power cycle. a. Power off the modem, router and computers. b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking. c. Power back the router and the computers. Check if it will be able to get online. If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below: 6. Connect wireless computer to the router. If you are using Windows XP with Service Pack 1, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Advanced tab. d. Please delete all the preferred networks then click on OK. e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key. f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router. g. Make sure not to enable IEEE and then click on Connect. If you are using Windows XP with Service Pack 2, please follow the steps below: a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Change Advanced Settings. d. Click on the Wireless Networks tab remove all the preferred networks then click on OK. e. Right click on the Wireless icon then click on View Available Wireless Networks. f. Select your network and click on Connect. g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router. If you are using Windows Vista, please follow the steps below: a. Click Start then select Connect To. b. Connect to a network window will show up. c. Select your wireless network and click Connect. d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect. From the above configuration, please check if you can now access the Internet.
Posted on Jun 15, 2009
Bervenjames
  • 12 Answers
SOURCE: Netgear wireless router WNR834B has died ... no
You need to return it if it is under warranty. If not you need to buy a new router. I suggest getting a Belkin.
Posted on Oct 21, 2009
Tp link tl-wr740n how to install without cd
simply, connect it via network cable (LAN socket), turn on, check your gateway ip address, then type it in web browser, name/password should be admin/1234 or admin/admin, inside set what you need...
Apr 25, 2014 | NetGear RangeMax NEXT WNR834B Wireless...
How do you connect your netgear to the computer
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 13, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How to turn Netgear WNR834B into a repeater
I don't think the Netgear WNR834B is capable of acting as a repeater but there is another solution. I would decide where I want to put the Netgear WNR834B for best coverage and then do the following. Go buy the Powerline Ethernet Adapters of your choice and put one at the main connection and plug a ethernet cable into a open switch port. Second go to where the repeater is to be located and plug the 2nd Powerline Ethernet Adapters in and connect to the Netgear WNR834B LAN port. Be sure to turn off DHCP on the Netgear WNR834B and assign a IP address that is not used. I normally use the highest address in the last octet so that I can remember for management. xxx.xxx.xxx.254. I hope this helps you.
Apr 28, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I need the install cd or a download for a version 5 netgear wireless router
If you connect the computer to the modem , does it works ?
If it works then modem is working. now connect the computer and modem to the router.
open the set up page of the router. change the Internet settings according to the ISP.
You don't need CD to install the router, you can do it without CD also
Click Here for more information about router and networks.
Jan 09, 2010 | NetGear WGR614 54Mbps Wireless Router...
How to reset Netgear RangeMax NExT Wireless Router WNR834B
Do a hard reset (20sec hold reset button, unplug for 20 sec still pressing the reset button and another 20 sec to turn on the power while holding the reset button). That should reset to defaults.
Jul 04, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Msg. conntected with limited access
Try this.
Unplug the Router.
Unplug the modem.
Wait about 15-20 secs.
Reconnect the modem.
wait about a minute or until all the lights are solid on the display.
Reconnect the Router.
Wait about another minute until everything is given time to start up.
Try connecting again.
If it still does that, it may be a problem with your computer that your trying to access with wirelessly.
My mother had that problem on one of her laptops, it turned out that her particular installation didn't support WPA or WEP incryption. I did a full reinstall and now it works.
If you want to avoid a full reinstall you can try uninstalling the wireless network card, then reinstalling it.(Make sure you go to your manufacturers web site first to download the proper driver for your model)
I hope this helps,
Simon.
Nov 19, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
How to install if i don't have the installation cd of the router?
enjoy,
Lee
Jun 12, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
126 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
