Question about Kenwood KR-V9080
I need re activate the m input on my krv9090 amp to allow the DVD sound
No sound from speakers when tv is playing
Try the changing the input on your DVD to " AUX", that input will allow you to play sound from your tv through the DVD
Oct 28, 2012 | LG LHT854 Theater System
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Dvd recordings from tv
You need to connect your incoming signal to the DVD recorder first. So either put your aerial lead (or cable as the case may be), into the aerial input socket at the rear of the DVD. Then you will need to go into the tuning mode on the DVD & tune in your stations. If you are on cable with a scart, then just connect the scart from the cable box to the DVD & select the input source (ie AV1), this will allow you to record
Jan 04, 2010 | GoVideo DV1130 DVD Player/VCR
I change Component Cable Video & Audio 6 cables
I might sound stupid but Double check that you`ve connected the correct connectors as in All Inputs plugs being used or All outputs plugs being used. If you have one of these leads with 6 connectors on one lead, (Audio Input L+R, Video Input, Audio Output L+R, Video Output) You need to make sure that if you get sound from the audio input plugs, then you must use the video input plug and vice verse. Ian
Jul 22, 2009 | Panasonic PV-D4732 DVD Player / VCR Combo
Need remote controller
Check out the Logitech Harmony series of remotes that can be programmed to operate all your electronics from activity-based buttons.  For example pressing the "Watch Movies" button will turn on the TV and select the DVD input, turn on the home theater, and turn on the DVD.  Then the buttons on the remote will control the appropriate device (home theater for sound, play buttons for DVD, etc.)
Go here for info: http://www.logitech.com/index.cfm/remotes/universal_remotes/&cl=us,en
Jun 02, 2009 | Insignia 42" LCD Flat-Panel HDTV
I need set up help
Most amps these days have to told which input is being used,ie if you have the dvd into dvd video input for picture and are useing coax or optical for sound you have to go into the setup menu on the amp and find the input menu and tell the amp the dvd is on optical or coax.
hope this helps.
CABLE GUY.
Jun 27, 2008 | Pioneer VSX-D510 Receiver
Hooking it up
To get the dvd working hook up to amp with a optical or coax lead to your amp digital in,set out put on dvd to give 5.1 sound,next put a phono cable from cable box to tv input on amp or sat input,now put phono cables from tv audio out to tv or other free input on amp.Set sound to prologic2 and you should have surround sound for all.
hope this helps.
CABLE GUY.
Jun 05, 2008 | JVC RX-6030V Receiver
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
16 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
