Error f8 in my ariston aqualtis aqm9d 49 u washing machine
Error f8 happens after switching the machine on where it stops
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
SOURCE: ariston washing machine error message
PUMP WASH BLOCKED WITH A SMALL PIECE OF CLOTHING UNBLOCKED AND MACHINE WORKS FINE
Posted on Apr 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
SOURCE: Hotpoint aqualtis giving H20 error
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Posted on Jan 11, 2010
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
Airston AQM9D 49 U giving F13 error
Already covered here
http://www.fixya.com/support/t14504284-ariston_aqm9d_49_u_display_error_code
Jun 22, 2014 | Washing Machines
Lavadora secadora ariston aqualtis aqm8d error f13
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
Dado
Apr 08, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston aqualtis aqlf9d
PLEASE URGENT!! I have the same washing machine WMW-5812.ER when i press the power on it does not start up why? Please help children getting back to school this week....pleaseee....
Jan 04, 2014 | Washing Machines
Hotpoint aqualtis error code F04
Indesit (Hotpoint Aqualtis, Ariston) 'F04' states 'pressure switch jammed empty, check pressure switch, wiring and module connections'.
It is not that unusual to find it cured by having the connections gently pulled apart and replaced, thus 'cleaning' the contacts back to correct operation ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 05, 2011 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
