Question about Siemens Washing Machines
Frount loading wm siemens E14-48 showin error code F36. Will wash clths but will not empty
  • 185 Answers
SOURCE: getting error code e:02 on
model number please
Posted on Mar 28, 2008
SOURCE: siemens s14.149 washing machine error
Mine was the front door catch!
Posted on Sep 24, 2008
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
  • 6277 Answers
SOURCE: Washer machine Siemens model: WM
Here are my general guidance notes for a possible cure ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 28, 2011
fixya167
  • 119 Answers
SOURCE: siemens xlm1600 drum doesn't turn - motor running - full load of wet washing. Inlet/outlet checked and cleaned - ok. Won't even turn when empty. Whats up?
something jammed between outer drum and inner drum or bearings jammed, if any off these then belt will be burnt Re: Jeff
Posted on Apr 12, 2012
F36 and "suds" keeps coming on. what can i do? He3t Kenmore washer.
Are you sure you didnt read the error incorrectly?
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Kenmore HE2 Plus Front Load Washer
My LG Intellowasher WM-1280FHD is refusing to spin, even when empty, making strange noises and displaying the code LE. I cannot find the manual to know what this means. Can anyone help?
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 14, 2010 | LG WM-2277HW Front Load Washer
Lg wm-2277hw front load washer getting a OE error code after cleaning drain hose and filter
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
May 22, 2010 | LG WM-2277HW Front Load Washer
LG WM-2077C CODE LE
LE stands for locked motor error. Sometimes just unplugging it for about 10 minutes will fix it, but if not you will probably have to replace the motor position sensor(hall sensor) or the motor.
Dec 05, 2009 | LG WM-2077C Front Load Washer
I'm getting an OE error on my washer--lg tromm 77wd941. I have emptied the lower drai, but I've noticed water in the detergent load area for a couple of weeks too, like it's not draining well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!
Nov 17, 2009 | LG WM-1832C Front Load Washer
What causes an OE error on LG WM-227hw front load washer
Nov 15, 2009 | LG WM-2277HW Front Load Washer
Oct 24, 2009 | LG WM-2277HW Front Load Washer
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
345 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
