Question about Cell Phones
Well I was trying for different clicking sound, for my camera but, what am I supposed to do?
  • Cell Phones Master
  • 673 Answers
What is the model of your phone? most of the mobile phones has only a limited sounds for cameras. You can't change them or add a new one.
Posted on Oct 29, 2012
Memory card error after two or three pictures on ist D S formatted fat 32 have around three memory cards different makes is it because its a class 4 card ore sometthing wrong with the camera itself?
I'm not quite sure I fully understand your question but, it sounds like you've been formatting the memory cards on your computer. They are supposed to be formatted in the camera.
Sep 26, 2011 | Cameras
My flash wont pop up and it makes a clicking sound and when it does finally pop up it the flash wont go off please help is it broken or is there somthing i can do to fix it
Hi tara shea, not broken.
If may be that the release magnet is locked
check the hook that holds the lamp unit that is supposed to return by the action of thespring, try moving it gently toward the front of the camera.
If your camera had a fall or a blow that can be taken out of the return spring anchorhook.
regards
Mar 18, 2011 | Nikon D3000 Digital Camera
Have a new didital camera I do not know how to use the camera features
It is always useful to read through the user manual to become more familiar with your camera and the settings it has.
Click on the link below to download your manual:
The user manual is supposed to explain the different settings so have a read through it.
Kind regards!!
Jan 06, 2010 | Vivitar ViviCam 5024 Digital Camera
Text imprint on Video with Fuji S700 - remove?
As for the video goblins: Have you tried reformatting the memory card (in the camera)? It sounds like a built-in advertisement, though www.jpg.com redirects to a site called accusoft.com which DOES do imaging software. Was it a free card from some promotion, or perhaps an off-brand card? Have you tried a different memory card and got the same results? I have an S700 and use it almost everyday, with different capacity and brand cards with no problems. Was the camera purchased new from a reputable dealer and came with a warranty (NOT "open box")? If using a different memory card doesn't solve your problem, I would tend to think that someone "flashed" the firmware in the camera before you got it and added those lines at the top and bottom of your videos. Does it do it when you are just taking pictures and not videos? Have you tried a different viewer program on your computer? Some freebie software video programs put watermarks (your ghostly lines of text at the top and bottom) into the video until you purchase the unlocked version. Do these text lines appear when you are viewing the video in the camera also? As for the "clicking" sound, I am at a loss because there is nothing "motorized" like in the old days of film when a motor was actually transporting the film through a shutter gate and sprocket wheels. No mechanical movement in digital photography, except when using the optical zoom. Is your lens cap swinging in the breeze and striking the camera body? Is the clicking sound steady and constant, or intermittent?
May 31, 2009 | Fuji FinePix S700 Digital Camera
Hi , I get an error message everytime I try to view my saved snap
Sounds like there's a problem with the memory card. Reformat it with the camera or try a different (new) one.
Cheers
Feb 09, 2009 | Fuji Finepix S5800 Digital Camera
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 14, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Camera lens
Apr 29, 2007 | Canon PowerShot A510 Digital Camera
Canon Ixus 40
Apr 27, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
My Camera has E18 Problem
May 07, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
