Question about Canon Ink Cartridge GPR15 for iR 2270, iR 2870
Canon ir2870 e000732-0010
My canon ir 2870 below eror code e000732-0010 solusin
  • Canon Expert
  • 242 Answers
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
Posted on May 13, 2014
KyoDoc
  • 38 Answers
SOURCE: IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
Posted on Sep 24, 2008
canontech
  • 1219 Answers
SOURCE: I replaced the black tonner on my Canon ir 3320n & this eror sho
try to set the toner a few times more, this error code is developer trouble.So it could be that toner isnt recognized, not properly inserted, or you have some tape leftovers on toner, or you have broken developer unit, or ...
Posted on May 06, 2010
canontech
  • 1219 Answers
SOURCE: error code 19
You have waste toner full!
Remove the drum, on top of drum there is cork, remove cork and vacume all the waste toner out.
Posted on Jun 02, 2010
SOURCE: Sir I have Canon IR
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Posted on Jun 09, 2011
canontech
  • 1219 Answers
SOURCE: canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
1) Press the asterisk key " * " on the control panel
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Posted on Jun 12, 2011
How to Clear Error- 000716-0010 in Canon IR2870 Copier?
E716 - There is an error in the communication with the pedestal.
After the presence of a pedestal has been detected, the communication fails to be normal for 5 sec.
1. Check the cable. Replace the DC controller
2. PCB. Replace the pedestal drive PCB.
http://www.smoothprinterservice.com/
Sep 22, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How do I solve Error Code - E000716-0010 In Canon IR2870
Failure of the communication with the 2-way unit
Description
When the communication with the 2-way unit is faulty after detecting the connection with the finisher.
Remedy
1.Install the 2-way unit.
2.Check the cable.
3.Replace the DC Controller PCB (PCB4).
4.Replace the 2-way unit driver PCB.
Canon ir4570 ir3570 ir2870 ir2270 service manual
Hello friend, you can find the canon ir4570 ir3570 ir2870 ir2270 service manual in below link:
Canon service manual:
http://goo.gl/GDAzQQ
Thanks
Apr 12, 2014 | Canon imageRUNNER 2870 Copier
Ir2870 how to solve error 602-0102
press *(additional function) then press 2 & 8 together and *(add. fun.) again . select COPIER on screen then <function>..<clear>...<system>...<hd clear>.... switch off and after a minute start. if problem continues.... replace hard disk.
Oct 18, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Eror code e00732-0010
check the cable that connects the scanner to the copier body
it sometimes gets broken you can wiggle it and reboot the device
thats the only thing that goes bad for this code
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
Canon Ink Cartridge GPR15 for iR 2270, iR 2870 Logo
448 people viewed this question
old marine
old marine
