Installing graphics card
I have an Emachine W3502. I am looking to install a Nvidia 8600GT. I found out that will need a psu bigger then the 300W stock in the tower. I ordered a 480W psu. Problem I am having is that I can not find any information on how to install the Nvidia graphics card. What information I can find is very general and stats to refer back to the manual for the motherboard. I did not get any manual for anything on the computer. Pretty much just want to know how to go about install the new graphics card.
    Problem Solver:
  • 12 Answers
Well you open the side cover and then you remove the old video card and then you install the new video card mke sure it is seated in the slot really good and put the screw back in repower up your computer a screen will come up say something like windows has found new hardware cancel that out by clicking on cancel then put your cd in with the software for the new video card and follow the instructions one it and you should be set when the computer reboots up
Posted on Jan 03, 2009
Palit 8 series geforce 8600gt drivers
Hello the driver can be downloaded here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
By selecting the model and your windows system.
Or use: Automatically find drivers for my NVIDIA products, by installing a small bit of software.
Good luck
Feb 22, 2013 | Computers & Internet
I lost the installation driver of this vga card.How can i get the driver on web.thanks.
Hi rempro2000,
If you're looking for the driver of your 8600GT you can download it here.
Product Type: GeForce
Product Series: GeForce 8 Series
Product: 8600GT
Operating System: Select your OS
Language: Select your Language
Feb 06, 2011 | XFX NVIDIA GeForce 8600 Graphics Card
IF I PUT MY XFX NVIDIA 8600GT NO POWER CPU
check the video card requirements currrent / watts...maybe your power supply cant drive it...try to use high wattage power supply...600watts true rated...
May 25, 2010 | XFX NVIDIA GeForce 8600 Graphics Card
I bought an Ultra LSP 650w power supply (upgrade) for my HP a1150y and it won't even boot up (fans come on & thats it). If I put the old 300w (oem) PSU in the PC, it works but it won't meet the power...
if thats wat the specs say then thats most probably the max youve just bought one thats to powerfull, and y did you need so much power the most powerfull graphics card in the world needs a 750watt power surpply, your computer is probably not designed to have major upgrades, and by looking at the specs i can see that your computer well putting it simply is **** for upgrading the specs are **** (no offense intended) i suggest upgrading to a whole new computer if you want that sought of power and graphics
Feb 17, 2010 | XFX NVIDIA GeForce 8500 GT 256MB DDR2 PCI...
EMachine Video Card upgrade
Ok so are you getting video from the card? Look in system information and see what graphics hardware the computers says is installed. Are you replacing a video card or did you add a card to the system? If you are adding a card make sure that you change the settings in the BIOS to boot first on AGP/PCI-E express slot. Make sure that fast write settings and bus speed settings are compatible with your card. For example if you purchased a 8X AGP card and your computer only does 4X the card may not work. Double check that you are trying to install the correct drivers for your card and operating system.
Sep 12, 2009 | E-Machines eMachines Desktop PC
Nvidia 8600GT not working well witg games
If you have Win Xp, Nvidia updated the driver on Jan 22 last month.Try the new driver. Link below:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/askIris.jsp
Feb 14, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Geforce 8600GT gaming problem.
whats power supple do you have? i have a 8500gt and it needs at least a a 350 watt most of those dells have a 305 watt upgrade to a bigger supple hope this helps
Feb 07, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
8800gt black screen
Hi Juan016, you have done everything right. I'd say the 8800GT is bad & return it for a refund. Run the 8600GT & the NVIDIA 6100 at the same time. If you check the middle of page 9 in your manual. NOTE: It states; if a PCI-E is inserted the bios will automatically run the PCI-E card. (No need to make a bios setting change).
It also says if you change the setting in the bios to, OnChip and PCIe VGA, the motherboard should run both. Depending what amount of memory you set the NVIDIA to run with. Once in windows check the amount of total memory the NVIDIA or 8600GT reports.
Example: You set the NVIDIA to use 64MB & the 8600GT has 512MB than the NVIDIA or the 8600GT should show 576MB. Its not that uncommon one buys a bad video card.
Reading the manual & windows not seeing the 8800GT tells me the bios did not see the 8800GT card. The card is bad. You’re doing just fine.
Mike
Sep 14, 2008 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Leadtek GeForce 8600 GT Extreme Video Card - 256MB GDDR3, PCI Express, SLI Ready, (Dual Link) Dual DVI, HDTV, Video Card
Usually the power quoted is for the entire system, not for the graphic card. The 8600GT systems (even yours with the overclocked GPU) would run fine with any PSU which comes true 300W (Single Rail PSU).
A key thing it seems in the amperage of your 12V, if its less than 18 or 20 (some say it should be even higher), it might not be enough for your graphic card as it does not come with an extra power socket (only the 8600GTS and above have this).
Dec 07, 2007 | Computers & Internet
Computers & Internet Logo
486 people viewed this question
David Payne
David Payne
