Question about Maytag Atlantis MAV6000 Top Load Washer
Water seeping in after load done (Hot water only)
Do I need to replace electric vale in washer?
  • 640 Answers
Yes the hot side of the water inlet vavle is defective...if you need any help replacing i will be glad to talk you through,,onthejob
Posted on Jan 03, 2009
Why is water leaking into my lg washer tub?
Your water inlet valve were the hot and cold hoses attach at the washer has most likely failed and is allowing the water to seep in.
Jul 10, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Fuse
Make sure the breaker is not tripped, make sure you have 120 volts at the plug outlet. make sure you water hot and cold water valves are open. sounds like to me your the fill valve is bad ( thats where your hoses hook to the washer) try to wash a load in cold water only then try hot water only. if you have power most likely its your fill vale
Aug 17, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Will let hot water in tub
try to see if there is anything on the drain pipe choking it if not must be the valve
Feb 27, 2012 | Roper RAS8445KQ Top Load Washer
My ecosmart gwl15 by fisher & paykel is dripping water inside the drum. It looks like may be from the bottom of the plastic spout, when I squeeze the rubber hose that is inside the machine it drips...
hi - first you need to know if its hot or the cold thats leaking - obviously one of the inlet valves is seeping, caused by dirt caught inside the diaphrams and generally not serviceable. if you dont use hot water for eg - swap em over or buy a new one and i will try & help you fit it.
First remove the power from the machine - take the screws off the top rear corners to gain access into the electonics, turn off the water too - remove the door and the display after - right the problem on the left side are the valves - either swap or replace - if you swap turn off the hot at wall so it wont seep.
Jun 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
My front loader LG washer works fine during the load, but when I come a while after the load is done, water has seeped back into the washer and I have run the drain cycle to get it out. LG says it needs...
If you have the capability its probably a leaking seal on the water input line at thetop of the water. Often its a simple hoseclamp that needs tightening. Without looking myself thats the easiest solution. Hope this helps!
May 09, 2011 | LG WM-2277HW Front Load Washer
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Water seeping back in washer after load is done?
Very possible your household drain pipe is almost the same size as the washers drain pipe. The house hold pipe should be approximately twice the diameter so as to allow equalising air in while water is being expelled from the washer. If at any time there is water flowback, it wont be forced into the washer pipe as it will now have an air gap.
Oct 06, 2009 | Kenmore 43142 Front Load Washer
Water dripping into the tub. Whirlpool top loading washer
You just need to replace the water vale.
The valve is not closing all the way when its off.
Sep 05, 2009 | Whirlpool Washing Machines
Water that seeps into washer after cycle is done
Hi, If you are getting water in the tub when the washer is off, you will need a new inlet mixer valve. You can test this by tirning the water off at the wall and see if any water seeps in. If you would get me a model #, Icould look this up for you.
Please let me know if I can assist you further.
Vic
Jun 01, 2009 | Kenmore Elite 45986 Front Load Washer
Water runs out of the rubber gasket inside the door
replace water inlet vale it has gotten debris in it and not allowing it to close
Jan 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
