Question about Bose Audio Players & Recorders
Change the language on bose remote
I am setting up my bose v35 and the language on the remote is an saian language. how do i change it to english?
KBFC ROXX
  • 59 Answers
SOURCE: Change Language Setting on W375
Hello there. please do the following. press the menu button>press the screwdriver option>press the wrench with a brown file icon>go down 6 places from the top and select it> you will then see english at the bottom. hope i helped!
Posted on Aug 04, 2008
mohammed387
  • 1952 Answers
SOURCE: changeing phone language settings
go to setting<phonesetting<languagesett< phone language english
Posted on Mar 06, 2009
  • 987 Answers
SOURCE: change the language english from italian
Go to Main Menu/settings/system/Regional Settings
Change the location here. If you have the problem still then try doing the hard reset in the same location. Once the phone restarts, then specify your region and language.
Do remember to backup your data before doing the hard reset. I hope it helps
Posted on May 23, 2009
  • 814 Answers
SOURCE: onscreen language change
All remote can perform this function through the on screen menu. You have to go to the setting function and find language and change it from spanish to english. You can find out more about this by going to the television's manufacturer's website and looking up a pdf copy of the owners manual. You will need a pdf reader and writer to read the manual and a writer to make a copy for your own use. In the manual all the settings will be explained and you will be able to change the language setting. I ope this information gives you some idea's on how you can solve your problem with the language on your television. Thank you for using FixYa and have a nice day!
Posted on Jun 20, 2009
  • 136 Answers
SOURCE: LG KF600 dont know how to change language setting to english
you're gonna want to go to phone settings, language, click english...
Posted on Jul 01, 2009
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
Why does my system keep muting on and off and my remote displays no signal
The batteries might be low on voltage if you haven't changed the batteries if you have the buttons may be stuck or it has been damaged internally you might need to contact customer service for warranty info and support!
Jan 16, 2015 | Bose Lifestyle V35 Theater System
I had Bose lifestyle V35, V20 try to link together. Bose link AL8 transmitter will not connect to receiver. both led is light solid green. Please help.
The commands for the Bose link system are actually going through the remote control system. In order to use the system you need not only a set of AL8 sender and receiver, but also a special remote control model RC48S2-40 these model numbers are slightly different for the US and for Europe. In addition you will need to activate the BoseLink connection through the system settings menu and you will need to tell the remote to which system it needs to talk. When you have done all that, there should not be any problem to "connect" the two systems. If this does not work, you may need some specialized help from a Bose specialist who understands this multi room set-up.
Nov 09, 2014 | Bose link AL8 wireless home-wide audio...
Bose link AL8 will not connect with the Lifestyle homewide powered system
Your v35 system needs to be programmed to work with the second zone wireless unit. Read the instruction manual how to do it, or let a Bose dealer set it up for you.
Dec 27, 2013 | Bose link AL8 wireless home-wide audio...
How to install a bose sa3 to a bose v35
How to install a bose sa3 to a bose v35....http://m.topix.com/forum/who/bose/TOH8RAETEKGB8966I/p2. See the link above . Sometimes audio cable quality n the ohm makes a difference . 12_27_2013_11_17_29_pm.png
Dec 12, 2013 | Audio Players & Recorders
Bad distortion of Bose Lifestyle V35
It may be due to one of the component attached. Detach all the components and test by connecting one by one. Try connecting radio at last.
Mar 24, 2013 | Bose Lifestyle V35 Theater System
I bought a Bose V35 2 weeks back. I played my system yesterday and switched off. Since this morning I am unable to switch on the system. Green light keeps blinking and I keep getting the message "iPod...
With this system being so recent from purchase you should return it to the store as it is faulty. DO Not Attempt to do any "Mr Fix It" type repairs as it will invalidate any warranty (standard is 12months from new in UK)
Jan 07, 2011 | Bose V35 Theater System
I cannot change the language setting
To return the base announce language to english press and hold the skip button for two seconds. To change the display language in the handset press the flash button, then use the CID button to sellect english, then cycle thru the rest of the menu by pushing the flash button until done. Hope this helps!
Apr 21, 2007 | GE 27995GE2 Cordless Phone
67 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
