Question about Konica Minolta Bizhub 600 750 Image Control Board 57aa-9016g
I have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy please tell me what is the problem ? note : i tried to vhange the heater and drum cartage too but not working regards
  • Konica Minolta Master
  • 6,161 Answers
When is the last time a full PM was done. with the counter properly cleared and require procedures where done after the developer and drum are replaced, did you clear the counters for the new drum?? Replacing the heater (FUSER/FIXER is not the problem) A good cleaning in and around the Photo drum and developer section with the developer replaced and counters properly check and so get a qualified Konica Minolta Tech out to look at the machine. My recommendation
Posted on Dec 26, 2015
Whats the cause for the code C8101 on a bizhub 600 when switching it on. please help
DF control board (DFCB) communication abnormality.
- Communication abnormality between the printer control board (PRCB) and DFCB. Causes DF control board (DFCB) Printer control board (PRCB)
Dec 06, 2014 | Konica Minolta bizhub Office Equipment &...
Copies are Very Dark
Are the prints ok? Did you tried to print a test page as follow: Utility -> User Settings -> Print Settings -> Print Reports -> PS Demo Page -> Start. Check this page and if it is looking OK, you isolated the malfunction to scanner area. Try a scan and check the quality, afterwards try to copy from DF and try a glass copy, check the quality.
If you need anything else, just drop us an email at office@bizhubreset.com
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 11, 2014 | Konica Minolta Bizhub c203 Copier
C-6708 code
Does your exposure lamp come on ? Mite have a problem with the scanner lamp or the Scanner reader that the CCD the black device under the big glass that views the document to be copied. Exposure lamp is what high lights the original document(s)
May 30, 2014 | Konica Minolta Developer 02xk Dv710 for...
Konica minolta bizhub c300
Check the scanner lamp. It is possible the scanner is faulty. Try to replace with a known working lamp. If this doesn't work you might have to check the scanner board or the CCD lense.
Jul 09, 2013 | Office Equipment & Supplies
What's your problem?i have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy p
When the last time the machine was cleaned in the drum area along with the associated sensors, when was the last time drum and developer replaced, every 250,000 copies drum developer should be replaced.
Oct 29, 2012 | Genuine Konica Minolta Konica Minolta...
What's your i have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy please te
Mite be that the copier need s a cleaning inside because it can not complete a copy cycle such as monitor the density of the toner on the drum have a tech do a cleaning when was the last time a 250,000 copy Preventive Maintenance Kit was done on it! Very 250,000 PM is done every 500K new drum. Does your machine a small wrench on the operator screen upper right hand of the purple/white screen
Oct 29, 2012 | Konica Minolta Developer 02xk Dv710 for...
Konicaminolta bizhub 600 machine dropping the toner. what is the solutions?
first toner must must and must be genuine, other wise it wont work in any conditions,
2nd toner density sensors and gamma sensor should be cleaned and all auto setting must be run .
third some time toner drops down the others side of the drum due to recycle clutch did't not work properly and all cleaned toner drops down after filled in recycle area,
Jan 11, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub 600 750 Image Control Board 57aa-9016g Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
