Question about Canon PowerShot A470 Digital Camera
I have charged my batteries for about 4 hrs and inserted into camera but after few minutes it indicates low battery signal
Is there any problem with my camera or else in battery charger.
  • Canon Master
  • 32,281 Answers
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Oct 30, 2012
SOURCE: Batteries "depleted"
Ok.  So far this has worked for me.  I had exactly the same problem and called Canon service after reading your post.
This is what they said to do, even though it sounds a little hocus-pocus:
• take out the batteries & camera card • clean the battery contacts ON THE CAMERA (those bumpy little things) with an eraser • click the camera on/off button 10 x • click the "take photo" button 10 times • put in newly charged batteries.
Hint:  Remove batteries every night. Never leave batteries in for more than 24 hours.
So this has now worked for 20 minutes!  There's hope!
Valerie
Posted on Feb 19, 2009
SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Posted on Jan 16, 2008
t00nz
  • 4738 Answers
SOURCE: Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Posted on Jul 21, 2009
  • 411 Answers
SOURCE: canon power shot a 470 problem with batteries i
problem with the mother board of the camera
Posted on Mar 01, 2010
  • 178 Answers
SOURCE: Battery not charging ?
Advise you to buy a new Digital Camera Batteries for Canon PowerShot SD1100 IS
Replacement for: CANON NB-4L
,cheap and good performance.
Posted on May 12, 2010
Battery not charge
the battery may have developed a memory from continually recharging a partially used battery. The battery charges to this point and reads fully charged but when used it shows as flat because the charged portion is the bit that is used and not the whole battery. Replace the battery with a new one and only charge the battery when it shows as flat.
Sep 15, 2013 | Sony Cyber-Shot DSC-F717 Digital Camera
I have been having this problem with my Olympus mju1040 for quite sometime. Everytime i tried to charge the battery when the battery low signal is blinking or when the screen blackout, it will be fully...
Try charging it for an hour even if it is indicating that it is already full in 10 minutes. If the battery still gets drained after a few shots, then you should change your charger.
May 22, 2011 | Olympus Stylus / mju 1040 Digital Camera
Canon EOS 300x battery problem: it doesn't work, even with fresh batteries. The LCD battery indicator blinks as they we're dead.
First make sure the batteries are in the correct position/orientation clean both battery terminal and look down inside the battery compartment make sure the "lower" connection is clean (shinny) if not you may need to use a pencil eraser with a piece of sandpaper affixed to it to get down in there and scrub off the corrosion. Another thing and I've run into this myself on a Canon Elan IIe was the battery indicator showed new batteries as dead but the camera attempted too function so, I just used it and used it and withing a few minutes the battery indicator showed the battery state of charge more accurately.
Mar 04, 2011 | Canon Photography
New cell phone battery trouble
Dont talk or use mobile phone when the phone is charging its battery and charge your mbbile battery for 10 hrs continusly before intinal use Only Charge your mobile when it shows " LOW BATTERY " Dont over charge your mobile Use the mobile to talk only when the network signal is high else use sms facility to communicate Use only original charger to charge the battery
Oct 22, 2009 | Sony Ericsson TM506 Cell Phone
Wont turn on
Well to be3 a 100% about the battery I would replace it with one that you know or is guaranteed to work. Camera batteries can look OK from outside and be completely collapsed inside.
No Charge lights can indicate NO battery and if there is one inside then it is dead and registers as a no battery ( no charge light)
The red light blinks in very low state, but totally discharged it will not blink and wont blink again until loeft on chareger for about 3-4 hrs to overcome the low state.
Jul 25, 2009 | Kodak Easyshare M753 Slim Digital Camera
Error message; has something to do with insertion of tape. Looks like triangle over straight line. beeps and blinks, will not play. Working when loaned to a "friend", returned in this condition...
Will it record on a new tape? Will it play a different tape? Have had a similar problem with a different camera. Think it had to do with the record mode / play back. A bit like standard play and long play - are there setting like that you could change?
Jun 26, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Battery pack or charger
Hi!
When you insert the battery , plug the power into the charger and the light turns ON (red or green) - the charger is OK. One indication that the battery is dead is when you charge it, after just a few minutes the full charge indicator will turn ON ( with Canon chargers the light for full charge is green). If that's the case, purchasing a new battery is the only option.
Have a nice day!
Oct 02, 2008 | Canon PowerShot SD600 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Battery charge
Put 2 batteries in flashlight and ran completely dead. Charged them in 1hr. 50min. Pulled plug per directions for first time charge and plugged back in. Light went out in about 10 - 15 min. Plugged in third time with same results. Is this normal. Haven't tried them in camera yet.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Canon PowerShot A470 Digital Camera Logo
256 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
