Question about Canon imagePROGRAF IPF605 Printer
Printing blank pages
I recently change the maintenance cartridge and the printer head as they were coming up with error messaged. Since these have been changed, when I load a roll of paper it just spits blank paper out and automatically cuts it into A1 sheets. Can anyone help? I have gone through a full roll.
  • paul
    paul Oct 30, 2012
    did you remove the piece of tape at the bottom of the print head?
    Problem Solver:
  • 7 Answers
Carriage-board have problem
Posted on Feb 19, 2016
3 Suggested Answers
  • 12 Answers
SOURCE: Printing blank pages, cannot detect any problems in maintenance
Sounds like your printhead is clogged, see posts in my profile for clearing out stubborn clogs.
Posted on Jan 21, 2009
  • 19 Answers
SOURCE: BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Posted on Mar 13, 2010
Testimonial: "You are CORRECT. I was using a new head/ink cartridge. Replaced with another one, and problem disappeared. Thank you for taking the time to respond"
Problem with my PC cant get mky printer to printer more than blank pages. Just bought new ink cartridges
Before fitting new cartridges and before removing them from their packaging give them a good shake.
If you think you have blocked nozzles stand the old cartridge in warm water.
Oct 22, 2012 | HP Officejet 6500 All-in-One Printer
My printer has not been hooked up for a good 6 months. I recently installed it again on a brand new laptop, and everything installed correctly however when I send a print job to it, the pages come up...
HI!
When the printers are out of action for a while and since its alcohol based ink it tends to evaporate and glogg the head or ink!The best thing to do is to get new cartridges or if it has a separate printhead replace it!!
Hope it helps!!
Apr 02, 2011 | HP Photosmart C4180 All-In-One InkJet...
Canon i965 prints blank pages
Yes those printheads do go bad, they burn out just like a light bulb. If you emptied cartridges then the purge/cleaning assembly is working properly, and the only other option is the expensive printhead.
Aug 20, 2009 | Office Equipment & Supplies
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
Jan 20, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Cartridge Aligment Failure
Then printer successfully printed alligment page you must to put this list on scanner glass to confimation and calibration of printing heads and press "Start or OK", without this part of procedure yours printer will be show error message.
Aug 29, 2008 | HP 190 Copier
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Canon imagePROGRAF IPF605 Printer Logo
82 people viewed this question
old marine
old marine
