Closed Captioning comes on every time i turn on the tv!
No matter what I try, CC turns on automatically whenever I turn on my tv. I can turn it off with my remote, but the TV doesn't remember that, and just turns the CC back on the next time I turn on the tv. Please, please help. The Closed Caption will not be turned off when I press the mute button. I turn it off with the remote but the captioning returns every time I press the mute button.
  • Anonymous Feb 18, 2009
    This same problem happens to me as well. Every time the TV is turned on the CC is on as well. The remote turns it off, but it is getting annoying that the TV doesn't remember the settings.
Apparently the 2002 Sharp model TV that I purchased has the closed captioning by default if the mute button is engaged. So there is no solution for my particular model, it has been built in this way. The only solution is not to use the mute button and lower the volume instead.
Posted on Jan 06, 2009
Samsung 6350 smart tv is stuck in closed captioning. tried everything to turn off cc
There should be an option in the Setup menu for CC (closed captioning) to turn it on and off. If it's already off, you're going to need a new Main board. (You might want to try updating the software first)
Feb 21, 2015 | Samsung Televison & Video
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
How do i turn off the closed caption on my toshiba 51h84 tv? i tried setting via the remote and changed the CC option to OFF but i still see the closed caption wording...it is driving me crazy!! help!
What is the source of your TV signal: Cable? Dish Networks? DirectTV? Antenna?
Many times the Cable/Dish Networks/DirectTV controller also has an option for closed captioning. Please verify that a controller is not setup to deliver the CC data.
Also, try setting the TV CC using 'C1' or 'T1' and selecting 'Enter' to accept the change; then come back and set CC to 'Off' again to see if toggling on/off helps.
Dec 31, 2014 | Toshiba 51H84 51" Rear Projection...
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
How do you turn on the Closed Caption mode
U have the tv original remote wright?Yes?Look at the tv remote look for a button that said CC,press that CC buton a couple of times for it to have like CC1,2,3..if the tv program u are watching offer Closed Captioning u will have it.Or tries the tv manual button on the tv bazel frame itself that said Menu.Press the Menu buton go into the tv funsctions look for Closed Captioning funsctions in there look for it and turn it on all like CC1,2,3... all on will also getting Closed Captioning for the tv programmng shows that offer it too.
Aug 23, 2011 | Durabrand DWT1905 TV
I need closed caption
Tv air broadcasting shows have to say it,to have closed captioning or have to have a white small sign that said CC to be able to get closed captioning ok.Look for it in ur remote there a button that said CC pushes that button go to CC1,2,3..now u will get closed captioning.Or go into ur tv Menu find closed captioning functions turn it on like CC1,2,3...or Text 1,2,3.. on.Now ur tv are ready to get closed captioning,for the tv air broadcasting shows,that have closed captioning.
Dec 10, 2010 | Broksonic TV
I am trying to turn on my closed captioning on my 19'' orion tv but dont see it... how do i turn it on
Usually you can turn on the closed captioning from the remote. There (should) be a button labeled "cc" that you just need to press once or twice until you get the closed captioning style you want. If your remote doesn't have this button, or if you don't have a remote, you could try two things. First, you could try (i'm not sure if this would work) going into the tv menu itself and searching for the closed captioning part, or you could just go out and buy a universal remote that has the "cc" key. I hope this helps! Sincerely, Der Strom
Apr 08, 2010 | Televison & Video
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
How to get closed captioning on Tv
Use ur remote turn on CC on the remote 1/2/3 CC 1/2/3 well get Captioning if the show have Captioning.
Jan 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Closed captioning
I experienced the same problem for about an hour before recognizing that the "continuous on" closed captioning had been activated on my cable box, not the TV. The signal feeds through despite the CC settings on the TV. If you haven't already, try checking the CC settings on whatever device is supplying your video.
Apr 22, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
