Question about Navman GPS
My Navman S80 is frozen on the USB connected screen. I have tried to hold power down and to delete the 'database.db' file via windows explorer, but no luck. Any other ideas??
  • 6 Answers
SOURCE: Navman icn 520 stuck on USB screen
I had this problem when I completely deleted the Backup folder from \My Flash Disk.
Restoring the backup folder allowed the 520 to operate properly again.
It is possible that you have a corrupted APPStartupSec.exe application. Without this file working it appears that the NAVMAN waits in USB mode for ever!
Hope this helps.
Posted on Jul 09, 2008
SOURCE: I have loaded upgrade SmartST
This is a new unit, i was looking for a warranty site and was on the wrong one, no I have not fixed it.
Posted on Nov 23, 2008
SOURCE: navman s80 frozen
just been on navman site,in tech surport it said hold on/off button down for 10seconds to reset.
im glad to say it works
Posted on Feb 01, 2009
  • 45 Answers
SOURCE: my navman s80 has frozen while trying to charge
Try this solution : http://www.fixya.com/support/t906770-no_map_displaye. Maby you will fix it just by reinstalling the software with SmartST
Posted on Apr 10, 2009
SOURCE: navman s80 boot up
on / off button jammed
Posted on Jan 26, 2010
How can find music.db in nokia 3110c
After you have installed the Oxycube....Open the Oxycube interface and connect your phone via USB cable by selecting Pc suite/Ovi suite.Open your phone drive and search the "HIDDEN FOLDER" and in the music you will see the music.db. select all and delete all the files which have suf-fix of .db...In case if it doesn't works delete it ONE BY ONE.Good luck
Sep 16, 2012 | Nokia 3110 Cellular Phone
Navman My50T - screen has frozen, can't get any other screen apart from initial start-up screen (except for screen showing connected to computer when connected by usb).
Had a similar problem with a MY60T.
Spoke to Navman support.
1. Connect your unit to the computer.
2. Use windows explorer to go to the Navman folder
3. Go to the database folder.
4. Delete "Database.db"
5. Switch off & re-start you unit. The databse file is re-created on startup
Dec 24, 2010 | GPS
My navman s45 seems to be frozen or just stuck on the same route also after i have reset it it still goes back to the same route which is stuck on and cant be cleared and the touch screen buttons dont work...
1. Connect Navman GPS to PC via mini-USB cable.
2. Go to 'Start'
3. Go to 'My Computer'
4. Open the Navman Unit
5. Open the 'Navman' folder
6. Open the 'Database' folder
7. Delete the following file only - 'dababase.db'
8. Close the folders
9. Disconnect the mini-USB cable then restart the Navman GPS by sliding the switch to 'Restart' then back to 'On' after 10 seconds.
The database.db file will be generated automatically once the folder is closed.
Nov 04, 2010 | GPS
Navman MY75T was working fine for several weeks, but today it won't start up. Tried to reset several times, but no luck. It gets to the Safety Agreement screen, and when I press the "Accept"...
1. Connect Navman GPS to PC viamini-usb cable. 2. Go to 'Start' 3. Go to 'My Computer' 4. Open the 'Navman' folder 5. Open the 'Database' folder 6. Delete the following file only- 'dababase.db' 7. Close the folders 8. Disconnect the mini-USB cablethen restart the Navman GPS by sliding the switch to 'Restart' then back to'On' after 10 seconds. The unit shouldstart & the database.db file will be re-generated automatically.
Nov 02, 2010 | GPS
Screen is frozen, can be turned on and off but wont go passed initial stage
May 17, 2010 | CaseCrown Navman S50 Portable GPS...
My playstation 3 will no longer play blue ray movies or DVD why is this. It now just shows a black screen that I can not get out of. How do I fix this?
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
I connected my Navman S80 to my computer to charge it and in the meantime I was clearing old files. I accidentally deleted everything from the S80 and emptied the recycle bin. Is there any way to get the...
have you not got a set up disc ?? if lost try emailing navman for new one or down load, check if you have only switched the functions off on gps unit or search pc if old file in in the desktop
Dec 26, 2009 | GPS
Sana e280 frozen screen reads Refresh Database
put the player in recovery mode by placing the hold slide button at the top of the player so that the red showes, held down the record button while turning on the player. upon connecting the USB cable the unit will go into the recover mode. Go to my computer and look for the drive which states "16MB Format" and copy the firmware files into it. Disconecting the cable after the files are copied will cause the player to reload the firmware. The player will restart and then shut off because of the Hold button position. Slide the Hold button back into normal mode and push the menu button to restart. The unit will power up and display the language settings. I went to the settings menu and changed the player USB setting to USC. I then placed the player in recovery mode again and went to the MY Computer again and set window to show hidden files. This allowes windows to see the database drive. I then ran chkdsk on the database drive which found a lot of crossed linked files. This then allowed me to delete all the files in the database. Upon comming out of the recovery mode the unit restarted normaly.
You can get the firmware at this site. http://mp3support.sandisk.com/firmware/e200/e200v101.02.18a.zip
Oct 11, 2008 | SanDisk Sansa E280 MP3 Player
Navman s80 frozen
Oct 09, 2008 | Navman iCN 530 GPS Receiver
Navman S80 will not let me go passed the safety agreement
When I turn my unit on all I can see is the accept/decline screen. The unit will not load the maps. How can I fix this?
Step 1
Connect your Navman Device to your computer via a USB cable.
Turn on your device and you will see a connection screen appear.
Step 2
Wait a few Seconds until a window appears on your desktop and then select “open folder to view” by double clicking on it
Step 3
Once you have opened this folder you will need to double click on “My Documents”
Step 4
Once my documents is opened locate and files that starts with “LOG00” and also “My Mileage” and delete them
Step 5
Once the above steps are done you may disconnected your unit from the computer.
Turn your unit on and enter your main menu page 2/2 and select “Preferences” then select “Route Options”
Once this is selected go to page 4/4 and un-tick “Enable GPS data logging” and “Enable trip recording”
Your unit is ready to use and will run a lot smoother due to increasing unwanted data and freeing space to increase optimum performance. We suggest that you follow these steps once a month to ensure optimal performance.
These steps will work on the S50, S80 or S90i. If you are experiencing this issue on an S30 or any other device, please contact Navman Technical Support on 1300 628 626.
I used this personally on my S80 after it died during my work as a Security Patrol officer and I was not happy, its all fixed now and I have my Nokia N95 loaded with the same places just in case.
Feb 04, 2008 | GPS
GPS Logo
66 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
