Laser replacement in nad c 541i
How do i replace my kss-213c vcd lens in my nad c 541i cd player ?does anyone know?
5 Suggested Answers
  • 42 Answers
SOURCE: Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Posted on Sep 27, 2007
SOURCE: Not Recognising a CD
I got a second hand 541 a few weeks ago. After many hours of listening pleasure an no problems at all, the machine stopped spinning CD's, both copied ones and original ones.
The sollution for my problem was simple after some figuring out.
Open the CD tray.
Power off the unit with the tray open.
Open it up.
In the CD frame in the back there are 2 srews that hold the CD engine unit in place. I untidied these screws just a little bit.
I also untidied the screws that hold the cd clamp cover on the top a little.
After this it loads all my CD's fine again.
Posted on Feb 28, 2008
SOURCE: KSS-240A replacement/adjustment in the Sony HCD-H1700
the laser assy should come complete if its only the eye itself only loosen one slide rail and slide the old one off and the new one in this keeps the laser alignment intact .coloneus
Posted on Aug 14, 2008
robotek
  • 1512 Answers
SOURCE: NAD 5425 CD Player display light out
Hi aartman
Yes it does have backlamps.
They are soldered to the PCB so you will need a few tools like a soldering iron, philips screwdrivers, solder, and some replacement lamps. Replace the lamps with this type from Farnell electronics. They have a 15000 hr life expectancy and last alot longer in the unit. I have tried many types of lamps over the years, and found these are the best choice if you want them to last.
FOR YOUR SAFETY-BE SURE TO DISCONNECT FROM THE MAINS BEFORE REMOVING THE LID
To get access to the lamps, you need to pull the main PCB out of the chassis to then get access to the bottom side of the printed circuit board where the 2 screws that retain the white lamp reflector assembly. Change both lamps with the type I mentioned,
6ab9edb.jpg Be careful not to flex the LCD display that is now exposed, it is quite fragile with the support of the lamp reflector cover no longer in place. ... reverse procedure to reassemble and away you go.
I am more than happy to talk about this solution with you further. Just ask away. Cheers
regards
robotek
Posted on Dec 12, 2008
What laser is in CDN 88 pro
Its looks like a SONY brand with KSS laser 213c .
Feb 13, 2014 | Numark Industries Numark CDN88 PRO DUAL CD...
Hi, I have a NAD C541i cd player when i turn it on i get three blue line on the display, i open the draw and insert a CD disc but the blue lines stay on the display and the disc don't play. can you...
The blue lines you mention should flash when trying to find
the 'Table of Contents' of your CD, even if a CD isn't loaded.
If when a CD is loaded and these lines flash for a while without
any CD info e.g track no. / disc length then it's more likely that a problem has occurred with the laser.
Various NAD CD players use the Sony KSS-213 Laser unit
and for some reason particularly with NAD CD players, they tend
to drift out of calibration over time so what i usually do when i come across this is very finely adjust the pot trim on the laser itself and testing a CD between adjustments.
Jun 22, 2011 | NAD C541 CD Player
The CD player will no longer recognize or play discs - or it takes ages to engage and play the disc. I think the laser is warn out. Is it replaceable, and is it cost effective to do this? Thanks, Ralph
I have the c521i with similar problem. It will play discs most of the time and sometimes can go for an hour or more before hanging up. Sometimes the disc is spinning and the laser is moving up and down (clicking) trying to read data. Sometimes the disc will stop spinning.
The replacement laser mechanism is a Sony KSS-213C and can be found by a few resellers on ebay for between $10 - 26, and also online at stores like MCM Electronics. This assembly has the laser head, gears, everything that needs to be replaced. I should get mine in the next few days. I also bought the 16 pin flex ribbon cable that is about 8 inches long that connects from the laser and goes into the circuit board. With basic DIY skills, this is a simple fix. A little care and effort is required on the laser assembly. I am told this will fix and will report back as soon as I get it installed and can verify it works.
Jan 01, 2011 | NAD C521 CD Player
I need a new transport for the cd HD 750 cd player,a better one if possible becose original makes a lot of noise thank you, George
This is what you need.This is the original Sony transport and mechanism for 750hd.
http://www.ebay.co.uk/itm/NEW-Original-SONY-KSM-213CCM-laser-lens-KSS-213C-Mechanism-and-Tray-/130593711673?pt=LH_DefaultDomain_0&hash=item1e67fde639
Oct 22, 2010 | Harman Kardon HD750 CD Player
My CD/DVD Player doesnt recognise any CD or DVDs.
the laser lens is dirty or damaged...a laser lens cleaner cd might help..if that doesn't solve it then the laser lens is damaged...you can purchase a relativley cheap dvd player that plays divx/mp4 files and (s)vcd video with cd audio and mp3 support. some come with usb ports and some support .jpeg files(pictures) depending on where you live the price varies.
Aug 25, 2009 | Canon PIXMA MP460 All-In-One InkJet...
My Numark Cdx won't read cds. It just ejects them.
GO ONTO YOUTUBE. TYPE IN NUMARK CDX FIX. Follow the video as instructed and this will be fixed.
Jan 04, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
Cd skips
If the unit continues to skip after cleanig the lens using a cotton swab and alcohol, the optics are failing and need to be replaced. These units use Sony optics (KSS-213C I think) and are readily available for $25 or so. Any service shop should be able to replace this for under $100 total.
Dan
Mar 11, 2008 | Audio Players & Recorders
CD player
It may be power problem/Lens cleaning
Dec 09, 2007 | Audio Players & Recorders
Numark cdx
Hi, i would try using different cdr recordable media or try a different burner if this dosent help then i would say your laser is at fault or in some cases i have had the servo pcb going faulty on this model. hope this helps. regards. paul.
Sep 02, 2007 | Nu Mark Numark Cdx Table Top CD Player CD...
Open Questions:
284 people viewed this question
 Grubhead
Grubhead
