Question about Jandy Laars Lite2 Ld 400,000 Btu Heater
Jandy lite2 heater has fl5 error code, all voltages look good
All test points have acceptable voltage except will not energize igniter. Power control board is expensivr to replace on a guess.
  • khadiyev May 11, 2010
    clean your filter/pump basket/ skimmer basket, check water level in pool/spa
    Problem Solver:
  • 6 Answers
If all voltage test points are within range, then it's 1 of 3 problems: Power Conversion Plug is faulty; Power Control Board is faulty; or Controller is faulty. Jandy says there is no way to test any of these directly. They recommend that you replace both the Power Conversion Plug (~$35) and the Power Control Board (~$230). Apparently when one fails, it can cause the other to fail as well. They said that unless the Controller has a lot of corrosion on it, then it probably is not the issue.
Posted on May 20, 2010
Jandy lite 2. How do I correct an fl 5 error?
FL5 is related to input voltage. You state that the voltages check out. Service code FL5, "brown-out condition exists",
will reset after the condition has been resolved.
However, the reset may take up to 3 minutes. The LJ
controller checks the power supply voltage every 3
minutes. If the supply voltage drops below 85% of the
nominal supply voltage, the display will show the FL5
service code and the heater will not start the ignition
sequence. The controller will check the supply voltage
again 3 minutes later. If the low voltage condition still
exists the FL5 service code will remain. If the actual
supply voltage is above 85% of the nominal supply
voltage, the service code will clear automatically from
the display and the heater will resume normal operation.
If the heater was in either 'POOL' or 'SPA' mode
when the brown-out condition was detected, it will
remain in that mode when the condition is resolved.
If
the water temperature is less than the thermostat
setting, the ignition sequence will start automatically
and the heater will operate normally.
Jun 17, 2015 | Jandy Laars Lite 2 Pool Heater 175,000 BTU...
What part failure produces error code FL 4?
igniter failure. this is a problem with either the hot surface igniter, or the main circuit board. if the problem is the board you must replace the high voltage chip along with it
Aug 18, 2014 | Jandy Lite2 Heater LJ175P - 175,000 BTU LP
What does FL-5 mean on a laars lite2 heater
May 23, 2014 | Jandy Laars Lite2 Ld 400,000 Btu Heater
I have a volt meter and would like to use it to test some connections to figure out the heater does not light. Can you tell me where to place the leads?
First start at the line voltage coming into the unit. The LD model is supplied power from an external source. Once line (supply) voltage is checked, start at the transformer and trace all the circuitry. Meter set at 50 VAC should do it. The supply voltage will supply 120 VAC to the igniter. Here is a link to the PDF manual fro Laars/Jandy/Waterpik Lite2 heater
Jun 06, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
My lite 2 system will not light . First it registers F7 and know it registers F5.What to do now
assume you mean fl7 and fl5 the heater has been intalled electrical wrong check your voltage and see the heater installation some miswire the heater
Oct 06, 2009 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Jandy Laars Lite2 Ld 400,000 Btu Heater Logo
1,125 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
