Question about Sharp 27U-S50 27" TV
Sony wega kv sw212m80 - tv pictures is larger hence the picture is cut horizontally as well as vertivally
2 Suggested Answers
rey jr
  • 149 Answers
SOURCE: sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Posted on Feb 25, 2008
My sony wega kv-34hs420 worked fine last night never had a problem with it before. Today i went to turn it on and i get no picture and the stand by light is blinking 6 times every cycle
your tv has problem in the horizontal circuit caps in the horizontal circuit should be checked also the jungle ic.and the regulator in the power supply.have a tech repair your tv if your are not a tech. good luck.
Aug 11, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture is cut off on sides but not top and bottom. The display channel (default 2) is cut off on the side to give you an idea. (purchased it new around 1998-1999).
With TV powered off, use remote control to successively hit DISPLAY, 5, sound volume +, and POWER all within a second of each other. This takes you to the Service Adjust Mode and the first thing that appears is the Horizontal Size Adjustment "HSIZ". Press numbers 3 or 6 to make the picture larger or smaller. Other things can be adjusted by using numbers 1 or 4 to go through the list but you could really screw up your TV so don't do anything unless you are sure about it. When you're finished hit MUTING and then ENTER to save the changes.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-32FS16 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony WEGA
It is TV problem in Tuning section hardware.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Jul 03, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Sony kv-32fs120
The 6 blinks mean no horizontal. Check the horizontal circuitry. I'll look up your specific model later and post more details.
Dan
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega no picture
Sony has had problems with tuners for awhile.
Aug 15, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sharp 27U-S50 27" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
