Question about Canon imageRUNNER C3170U Color Copier
E00020-01a8 ... hi ! i have canon ir 3170ci i refill color toner in cartrize & than machine appear err code e00020-01a8 .. . so pls the my problem solve
  • 1 more comment
  • anand desai Nov 02, 2012
    e000020-0490
    machine appear err code e000020-0490 .. . so pls solve the problem
  • karl dave dordas Dec 18, 2012
    check the toner sensor and drum cleaning blade
SOURCE: Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Posted on Apr 09, 2009
  • 118 Answers
SOURCE: Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Posted on Jul 16, 2009
redzventures
  • 149 Answers
SOURCE: HOW DO RESET TONER DISPOSAL FULL,AFTER REPLACING ON A CANON IR 28
You have to enter servcice mode and reset the error code. Press the 'head' key with the star inside it - then the '2' and '8' key at the same time - then the HEAD key again. This must be done fairly quickly and then you're in the service mode. Now, from the screen select 'COPIER' then the 'FUNCTION' key then 'CLEAR' ---->'ERR' ---------> 'OK'. Now turn the machine off and on again. Your code should be gone. If not, you may have to clean the waste toner bottle neck where the sensor light shines through it.
Posted on Jan 20, 2010
Testimonial: "THANKS ALBERT"
FixinFax
  • 3085 Answers
SOURCE: canon ir 2016 is displaying
there is a black switch knocked out of it's holder.
Posted on Feb 14, 2010
SOURCE: CANON IR C6800 ERROR CODE E000078-0001
error code E000005-0000
Posted on Aug 26, 2010
Canon ir 4580i e000020-04c0
Trouble in the supply of the toner from the toner cartridge to the developer. Too much toner is supplied to the developer. Broken or disconnected wire in the ATR sensor.
Replace the drum unit (check its connections).
Black in yours.
Jan 29, 2014 | Canon iRC4580i
What's your problem?my problem is canon np4050 machin err cod (e020)
just clean the hopper and dp unit then refill the toner ,or remove the dp connector (do not connect it)but after that the hopper dose not work and refill toner directly into dp
Oct 11, 2011 | Canon NP 6050 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
CANON MODEL IRC2880 error code e000990-000
I have an error code E000990-0000 pliiz help me fix this
Jan 05, 2011 | Canon imageRUNNER iR C2880 Color Copier
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
Jan 19, 2010 | Canon imageRUNNER 7200 Copier
Canon IR3300 dark print out
You refilled the toner. Don't recommend refilling the toner. If you're going to spend the money on a copier. You should get genuine toner.
I suggest you make a service call and use genuine toner in future.
Aug 17, 2009 | Canon NP 6050 Copier
Canon imageRUNNER C3170U Color Copier Logo
50 people viewed this question
old marine
old marine
