Question about Onkyo TX-DS939 Receiver
I have an Onkyo TX-DS939 that only produces high pitched buzzing
It started when the unit got hot (due to the two fans not coming on). This occurred about 6 months ago. Ever since then, the receiver (once turned on) would take between 2 to 20 minutes of being "on" before a click/noise occurred and sound would generate. Last week the receiver started making a high pitched feedback sound and we lost the all audio besides the feedback. I lost video and tracked it down to some bad connections on the bottom of the board (this is resolved).
I have a couple capacitors that look swollen on the main board, but unsure what else could be driving the sound issue. Any assistance or a schematic would be appreciated.
Thanks!
  • 6 Answers
SOURCE: need to buy the jumper plug
What do you mean by a jumper plug. Are you referring to the preamp jumper plugs?
Posted on Sep 01, 2007
SOURCE: desply and sound gos off Onkyo TX-DS939
On my device there were quite a few bad solderings on power card. May be you have the same and it does not tolerate heat. Power card is that horizontal one on top, when you open the box. It is easy to remove so that you see under the card to check those solderings. One screw from left side of case, which holds that noise eliminator on AC lines, six screws from back keeping those connectors and four screws away from board corners. I disconnected only that connector in the middle of card, because it was a bit tight. Then I was able to turn that card upside down and after some fixes to those bad solderings device is like new again.
Posted on Jun 26, 2008
SOURCE: Onkyo TX-DS939
I have to ask the obvoius, did you get the manual, have you used the onscreen menu to set up the speakers, you can calibrate the speaker levels on the TV screen if you use the S video or RCA vidoe connection .have you turned off tape monitor?
Posted on Jun 28, 2008
  • 4234 Answers
SOURCE: ONKYO TX-DS939 (sound and heat/fan issues)
This sounds like the amp is seeing too small an impedence load. In other words, the amp is expecting to see an 8ohm load and is being presented a 4 or 2 ohm load. This will force the amp to work really hard and generate excessive heat. Does the amp generate sound at all? ever? If not, then you probable have a situation with high frequency oscuillations that you can not hear. This means that the amp is sending out a lot of power to the speakers that the crossovers are shunting to ground. Without seeing the output of the amp with a scope, I can not confirm this. This is not a problem that will be solved remotely. Bring the unit to a shop and request that the output be examined using a scope to check the waveforms. I suspect that a bad feedback look internally is causing the generation of the high frequency signals.
Keep us posted.
Dan
Posted on Oct 29, 2008
SOURCE: Connecting Airport Express to my Onkyo Receiver
Plug it into the cd input, with the two rca cables. We've had this set up for years. No longer use a cd player at all.
Posted on Apr 02, 2009
Problem with onkyo tx 919 unit
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Jan 01, 2009 | Onkyo TX-DS939 Receiver
GETTINF OVER HEAT
Onkyos are notorious for running a bit warm - though if yours is excessively warm, double-check the impedance of, and wiring -to- your drivers.
Nov 13, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
Keep us posted.
Dan
Oct 29, 2008 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939
Apr 27, 2008 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939 optical selection problem help!
That coaxial, opt-1 and opt-2 are available only if they are not selected to some other channel. So you have to check if opt-2 is selected to Video-1,2,3,4,5,6,7,CD or DAT. Change that to Analog and then opt-2 is free to another device.
Mar 24, 2008 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939 Receiver Problem
+22v line is missing. Check for 22v at R9207, not present check R9201,2 0.22ohm, R9203-6 1 ohm. Check also Q9201 12v reg ic, it supplies the led in the volume ctl. While your in there, solder up any cracked solder joints, bad connections.
Nov 04, 2007 | Onkyo TX-DS939 Receiver
Need to buy the jumper plug
Sep 01, 2007 | Onkyo TX-DS939 Receiver
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Onkyo TX-DS939 Receiver Logo
64 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
