Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Wd external hard drive i can't see the datas
  • Western Digital Master
  • 27,725 Answers
Figure out whether you need a hardware or software fix.
Look for grinding sounds from your drive or humming that starts or stops.
These are signs that the actuator arm and discs are no longer in alignment and your drive is timing out.
If it seems as though nothing is wrong with your hard drive, it's probably time for a software fix.
Run one of the many software fixes, if you think the problem is related to software.
These programs feature on-screen directions, making it easy for you to progress through them.
If this works, you don't need to fix a physical problem.
Remove the many tiny screws that holds the drive together.
Eventually, you'll get to the innards of your drive.
Be very careful not to bend or force a piece to go where it doesn't want to.
Determine if you've set things straight.
Look to see whether anything was loose inside your external hard drive.
If you have recently dropped it or traveled with it, it is possible that something came loose.
Also check that all the arms and platters are straight and do not appear bent in any way.
If they are bent, straighten them with your hands or pliers.
Put everything back together and check that everything in your external hard drive is working properly.
Try using the external hard drive on another computer.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb but its not working ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
hope this helps
Posted on Oct 30, 2012
SOURCE: Help!! Western digital 500gb external hard drive ticking noise
Yes. This is going to sound strange. Put the drive in a plastic bag and put it in the freezer. Next day, take it out, hook it up, and see if it is recognized.
If so, under My computer, right click on the drive - click Properties - then Tools, then Error Checking. Check box Automatically Fix File System Errors. Let it run. If everything shows up, be ready to transfer wnat you want off of it.
Freezing shrinks the metal parts . Microscopically, but often enough to get stuck parts free enough to get working.
I just went through this with a 750Gig Book. now i have reformatted the drive (after transferring all over to new drive) and the clicking is gone and all disk checks are fine and i wonder whether to trust this device ever again... Hate to just throw out a large drive.
Posted on Apr 05, 2009
darkoh69
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
  • 81 Answers
SOURCE: My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Posted on Jul 10, 2009
cnavarro
  • 2460 Answers
SOURCE: WD External Hard drive does not work no power to it
External drives tend to use power supplies at 12V DC and 1 amp or just a little bit over. You could read the output of the power supply with a digital volt meter. If you have power and the enclosure still refuses to turn on, you could buy another enclosure, another power supply, or just a naked USB to IDE adapter and pull the drive out of the existing enclosure.
Chances are, the drive you get out of the housing will never be going back into that case.
Posted on Jul 11, 2009
  • 497 Answers
SOURCE: Wiping WD hard drive
I suggest that you use Darik's Boot and Nuke ("DBAN")application to completely Esare the Hard Drive. It is a freeware application.
Darik's Boot and Nuke ("DBAN") is a self-contained boot disk that securely wipes the hard disks of most computers. DBAN will automatically and completely delete the contents of any hard disk that it can detect, which makes it an appropriate utility for bulk or emergency data destruction.
For detail visit:
http://www.dban.org/
Good Luck!!!!!!!!!!!!!!!!
Posted on Sep 08, 2009
Recover data without formatting
You may take a look at this external hard drive data recovery tutorial that helped me before.
Jan 02, 2013 | Western Digital 1TB WD ELEMENTS USB...
Please say someone has a solution for me, very worried i've most my life's collection of music and movies =[
Try the WD USB hard drive in another computer. If you can access your data on another computer then backup your data.
If the WD USB hard drive is faulty then -
It is not possible to recover data from faulty hard drivesby mortals such as you and I.
There are companies that can recover data from faulty and damaged hard drivesBUT they wll charge an arm and a leg for their services.
Feb 23, 2012 | Western Digital 1TB WD ELEMENTS USB...
My WD External Hard Drive for Mac will not power up? Is there anything I can do without paying for Data Recovery? I've only had it about 4 months.
you can purchased an external usb case from newegg.com I would first take the hard drive out so you can identify whether you need a SATA to usb hard drive or IDE to usb harddrive. Connect the hard drive in and see if it will power up.
Feb 18, 2012 | Computers & Internet
I have WD 320 external hard disk, it was working good , before 2 days its stop working, my computer can detect it but the size is zero and i can find my data
If it is detecting it as size zero the drive is damaged.
To be sure you can run WD's Data Lifeguard diagnostic http://support.wdc.com/product/download.asp?groupid=612&sid=3&lang=en
But it's probably the case you will need data recovery help. This guy does it remotely and works for donations. http://FreeDataRecovery.us
Jul 19, 2011 | Western Digital Passport 320GB External...
External WD 1TB. I cannot retrieve my files it says Parameter is incorrect when that is gone It shows there are no files on my HD and there are plenty of files all psd files as well
I'm sorry to say that this may be due to a corrupt HDD. WD Hard drives tend to die far too fast (I know too well unfortunately).
If this is under warranty, I would call up WD support service for a free replacement.
If you want to take more invasive steps, I will be happy to help you try and recover your files.
Feb 23, 2011 | Western Digital My Book Essential 1TB...
It make tic noise when the hard drive is running
This sound is the heads of the disk hitting. The drive should be backed up immediately to another.
You can put this drive into a drive enclosure to clone it to another.
This drive will stop working and there is no telling how soon that failure will occur.
Jun 06, 2010 | Western Digital Caviar SE WD1600AAJS 160...
WD Eliments 1T external HD. hidden data
hi there could be a couple of things you can try, you could, ( if you have xp ) have the drive in, then go to my computer, then tools, then folder options, click, view, then look down the list for show hidden files and folders, that's one, the other is to take the drive caddy apart, remove the hard drive ( as they are just normal hdd's in external boxes ) connect it up to a spare port on your desktop computer and see if you can transfer files that way, ( note! this will void the warranty on the drive case if you do this if it is still under warranty ) the other way would be to get a data recovery program, like winundelete, which you should be able to find on either your computer or the net for free, hope this will help
Apr 05, 2010 | Western Digital Elements powered by WD 320...
My WD external hard drive stopped working
wd external hard drive making ticking noise and seem to have lost all my photos and music
Dec 17, 2009 | Western Digital Computers & Internet
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
73 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
