Color problem in Bravia KLV 32V400A
I am experiencing a brighter images (not true color) thru all the mediums i.e TV/ DVD /PC on my TV. I tried factory reset but this did not help. Someone suggested that there is a IC just beneath the power switch that needs to be replaced. Can someone help?
  • 713 Answers
SOURCE: We have a Sony Bravia lcd tv model KLV-S40A10 - no power
Hi,the problem is from the fuse in the tv,it's blown and it's a means of in-built security against power fluctuations from damaging the unit,so the solution is to replace the fuse of the TV to restore your unit back to a normal working condition.
Be cool.
Posted on Jun 13, 2010
SOURCE: Panasonic TH-50PX60U Plasma TV no red color
We had the same problem with a different model plasma tv. My wife tried unplugging the tv for a minute or two, but we still had the same problem. I unplugged the tv and left it unplugged for over 8 hours, then plugged it back in and the problem was fixed.
Posted on Oct 17, 2008
jerryg50
  • 1689 Answers
SOURCE: Green color
The blue color channel has failed. There are many types of faults than can cause this. In some cases it may be a simple connection from one of the cable assemblies, but not often.
If there is a failure, the technician will change the appropriate circuit boards to fix the fault.
This type of fault can be expensive to service.
Jerry G.
Posted on Feb 10, 2009
  • 197 Answers
SOURCE: lg plasma tv lost red color
bad component cable
Posted on Jun 07, 2009
  • 53 Answers
SOURCE: 40xbr2 bravia kdl sony LCD tv. The screen shuts
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
Posted on Jan 22, 2010
I have a problem with my sony bravia LCD Model KLV-32V400A. white back light no image and sound is okay. please show me the solution.
T'Con board fault. check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 22, 2017 | Sony Televison & Video
How to fix overlap color green and red on the lcd tv screen?
Mostly it is due to the cable TV operators defect.
Or reduce the Sharpness by going to Settings.,in the LCD tv.
Or try reducing the COLOR.
Aug 25, 2014 | Sony KLV-40BX420 40 1080p Full HD Bravia...
Picture look like a negative film. color not normal. no green color
you might want to start with the t-con board. it can cause green colors missing
Nov 11, 2013 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony bravia klv-32t550a
Hello. When a backlit LCD screen becomes pink or red in color (I've seen other color variations too), it is the backlight lamp itself. A fault it the bulb causes the wave length of light that we see to change, and our eyes perceive the change as a change in color. Replace the backlamp or have a reputable tech service it for you. :)
Sep 29, 2012 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
I have a sony bravia lcd tv of 32 inches bearing the model numner KLV- 32S400A.. the prob is the pictures colour is turning into a negative image after 10 mins of switching on the tv. could you pls let me...
This seems like a T-con board problem as its responsible for several picture functions including color convergence. Or it could be a bad LVDS cable (inside the TV) I can ship you a new T-caon board for $150.00 or take it too your local shop repair shouldn't cost more than $250.00....
http://tvtechwork.webs.com/
Oct 18, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
My Sony KLV-32M1 doesn't turn on. No lights, nothing. Anyone experienced this problem?
try to check the ac cable if ok open the back of your tv and check the fuse if busted and no black color try to replace it
Oct 15, 2010 | Sony KLV-32M1 32 in. HD-Ready LCD...
I have a KLV-32U100M and recently I've noticed a wide bar of color rolling up the screen and a I hear a slight hum from the speakers. This occurs when different devices (cable box, dvd player, Wii) are on...
You may have an earth ground problem with your house electrical wiring-- third prong in AC socket. Get a 3-prong to 2-prong plug adapter ( also called an "AC-cheater plug") and put on TV cord. Try again.
May 01, 2010 | Sony BRAVIA KLV-32U100M 32 in. LCD...
Recently bought a Sony Bravia 20KDLS4000. Sony DVD player DVD-NS575P was compatible with 3 year old Sony TV but with Bravia, the DVD image is in Black and White. TV gets color fine. Thanks for your...
Try to set your video output settings on your dvd player . I assume you used to connect to your old tv by using svideo and now you are using another connection like component, scart or hdmi.If the video output setttings on your dvd are still on svideo you will have to set it to rgb or component or else you will get black and white images..
Sep 29, 2008 | Televison & Video
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
