Question about Sony KP-51HW40 51" Rear Projection Television
Picture on sony proj. kp57wv600 has been looking "hazy" lately.
Is it possible to clean a) lens or b) mirrors. I remember when they sold
me the set - that a service call would include cleaning of the mirrors.
Never had a service call but remembered the statement.
  • Sony Master
  • 5,138 Answers
Remove top & bottom back to clean Mirrors and Tube lenses.Use windex.
Posted on Jan 03, 2009
WHY COLOR IS HAZY?
Model indicated is a projection set with three picture tubes.
Cleaning may help your problem--two ways to do this-
with set unplugged remove rear cover and clean the three large black lens you cannot miss--if dusty the picture will be dull and darker--should be done once a year.
Peek up inside to the rear and look at the mirror--unless grimy leave it alone.
Other way is to remove entire screen unit which if you have not done that entails some danger of damage to the screeen.
Try cleaning the lens to see if improvement.
Jun 12, 2012 | Toshiba TP50F60/61 TV
NEED JUST THE LENSES FOR MB',, 2003 320M LIGHTS ARE FINE , BOTH LENSES ARE HAZY AND BAD
The lens is not sold separately, you must replace the whole assembly. This assumes you are talking about the headlight lens.
May 24, 2012 | Cars & Trucks
I bought a 800 to 1200 lens it seems to have a hazy look when I take pictures I have tryed different distances and I use a tri-pod and wired remote any tips
There are several possible reasons for this.
You may be seeing haze. With such a long lens, you're often taking pictures of things very far away. In such cases you're going to get haze (smog, smoke, fog, and other stuff in the air). A UV filter can reduce the effect somewhat. To see if this is the cause, try taking some pictures of something closer (like the opposite end of your living room) and compare.
If the sun or other bright light source is shining onto the front of the lens, that will reduce contrast and produce a hazy look. Use your hand or a piece of black cardboard or something similar to shade the lens (being careful not to get the object into the picture). Take pictures away from the sun and toward it (not directly toward it, just in its general direction) and compare.
The lens may be dirty. Clean the front and back with lens tissue or a microfiber cloth. Don't take the lens apart to clean its innards unless you have a lens collimator and other gear needed to put it back together properly.
Even with a tripod and remote, you may be getting some camera shake. If your camera has a mirror lockup or exposure delay mode, use it to damp out the mirror slap. If your camera doesn't offer either of these, try using the self-timer.
Also, make sure your tripod is sturdy enough. It's a heavy lens, and even if your tripod holds it, it may not be holding it very steady. Try putting your camera on a tabletop and shoot something at the other end of the room and compare the results.
Mar 13, 2012 | Cameras
The picture is almost hazy and is kinda dim. picture not bright??
have you tried to take off the front screen and clean the lens and mirrors yet? if this is a philips 9or a magnavox you will most likily need to change the fluid inside the picure tubes
May 08, 2010 | Televison & Video
Mitsu #WD52327 DLP replaced bulb but hazy picture
Did you clean the small mirror. Dust will cover this mirror and give you a very hay picture. This is easy job and takes 15 minutes at the most. Someone posted detailed destructions on how to do this already if you look for it under WD52525 hazy picture.
May 27, 2009 | Mitsubishi WD-52327 52" Rear Projection...
In manual mode 20 d is not caputuring the bottom 1/6 of the pic
The mirror doesn't seem to go up properly, get off the lens and check the mirror
Nov 19, 2008 | Canon EOS-5D Digital Camera
Enhancing picture quality
You might try taking the screen panel off, taking care to look for attached connectors. Make sure unit is unplugged before attempting this. Use a good glass cleaner to clean off all three projection lens assemblies. Do not attempt to adjust these lens, just clean them. Also clean the reflecting mirror at rear and inside surface of the screen. This should improve brightness and focus if they were soiled with dust
Jul 29, 2008 | Sony KP-51HW40 51" Rear Projection...
Blurry partial picture on a 42" rear proj tv
There may be dust on Lamp or at front screen. why dont you open rear cover of TV and give a close look?
May 28, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony kp57wv600
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 29, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
128 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
