My stereo system keeps skipping tracks whilst playing can you help?
Hi, whilst im playing cds , the cd player skips tracks whilst playing cds and will finish cds early . Ihave checked the manual to see what this problem could be however it does not provides me with any answers can you help please?
    Master:
  • 444 Answers
The lazer is going on it. End not reading the info on the disc properly,
Posted on Oct 29, 2012
  • 15 Answers
SOURCE: RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Posted on Jun 24, 2008
mjap
  • 107 Answers
SOURCE: Skipping CD
try to adjust the trimpot/variable resistor.
Posted on Feb 02, 2008
AvioriX
  • 689 Answers
SOURCE: Getting a whine from CD player
Have you performed lens cleaning process?
Posted on Mar 06, 2008
SOURCE: cd's skip
all the rca's have been released without quality control... you will have to open and adjust the potentiometers (the adjustible resistors on the main board) to re-calibrate the laser timings. However the way that the boards are mounted inside the boombox's chassis you will need to take apart everything to be able to reach the main board (inside vertical right side board with large heatsink and fan) without causing a short (as to be able to properly adjust these you need to have a cd playing and the whole thing needs to be upright.
I would recommend throwing it all way, not worth the time if you don't have the patience.
Posted on Oct 15, 2008
localwonder
  • 6784 Answers
SOURCE: CD player not tracking right
These are the early signs or optical lens assembly failuer. i would start preparing to replace this assembly. the tracking motor and rail are damaged.
Posted on May 28, 2009
The cd player goes into a "skipping" "playing really fast" mode occasionally. Esp. 3rd track, 1st cd. Always has.
It's having trouble reading the CDs. The thing that reads it could be dirty. But try a different cd. The CD player is getting old and if there is even a small scratch it will be hard to read it. A new CD player would be the way to go
Mar 14, 2013 | Audio Players & Recorders
SYSTEM SKIPS CDS AND MUDDLES SOUNDS
The laser pickup over time becomes weaker until it starts skipping and will not play sound in some cases. Try a cd cleaning kit and follow instructions, if no change unit will need to be replaced.
Aug 16, 2012 | Venturer Home Stereo AM/FM Cassette 5 CD...
I have a 2006 Mazda 3 and the cd keeps skipping to the point that Im not able to listen to my cds
Sounds like your cd player is dirty or the disk you are trying to play is scratched and not useable?
You can purchase a cd disk cleaner at any department store or office supply. All you do is play the disk and follow the instructions. Some come with a mix of alcohol & water and have small brushed on the disk itself to place the liquid and this helps clean out your equipment. Others clean without liquid.
Check the disk itself for scratches and try wiping it off with a lint free towel. After cleaning your cd player, try playing it again and if it still skips - replace the cd. If a brand new disck skips in your disk player after cleaning it then your lazer might need repair and I would recommend taking it in to a local stereo installation and/or repair shop.
Jun 07, 2011 | Car Audio & Video
My Sony CDP-XA7ES CD Player can play only up to 6 to 9 tracks depending on the length of the tracks n then stops.
replace the spindle motor. the motor's speed varies while playing cds and a worn motor will not keep to the correct speed for playback of certain tracks on various points of the disc and will cause skipping and even stop altogether.
hope this helps.
Apr 02, 2010 | Sony CDP-XA7ES CD Player
My jensen wont play cds wen it dose it skips
use a common cd/dvd optic cleaner .... they are cheap .. what is going on is your cd player cant find a track so it shuts off ..
Feb 10, 2010 | Jensen Car Audio & Video
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Skipping all CDs
Laser is duff uses the old sony kss family i believe,easy to change and get on ebay..
Jan 02, 2009 | Yamaha CDX-393 CD Player
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
Recongnizing cds
no i did not fix the problem yet.sad to say but i guess i will have too seek advice else where for the fact of i wasnt willing to pay for this service.sorry for the inconvience.maybe one day i may use this service.thank you
Sep 27, 2008 | Venturer Home Stereo AM/FM Cassette 5 CD...
RS 2653
Feb 10, 2008 | RCA 100-Watt Stereo System With 5-CD...
161 people viewed this question
 Grubhead
Grubhead
