Question about Samsung SCX 4521F All-In-One Laser Printer
Display document jam - Samsung SCX 4521F All-In-One Laser Printer
  • 48 Answers
That normally refers to the document feeder on the top of the machine, take A damp cloth and clean the rollers that pull in the paper, also check that there is no pieces of paper left behind from A previous paper jam, that will affect your paper sensors
Posted on Oct 30, 2012
Display panel shows 'original loaded' even when no document loaded
in ADF ( automatic document feeder ) check if there is jammed paper or clean paper sensor it may dusty
Dec 01, 2014 | Office Equipment & Supplies
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
CHECK 5100
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
Feb 20, 2012 | Office Equipment & Supplies
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
The scanner keeps jamming. i try to scan form the document feeder &the papers keep getting stuck. It will not complete a scan!what do i do?
In summary: * Very unintuitive, convoluted and unpleasant to use (same on Win2K as XP) - sometimes the SW hangs during scan and needs a reboot - sometimes the SW crashes with a dialogue "try reinstalling HP software", and needs a reboot - sometimes it scans and after conversion to pdf
Advantages: I cannot see any advantages with this product
Disadvantages: Software is convoluted and unreliable, paper jams are difficult to clear
function showHideReviewText( sType ) { if ( sType == 'more' ) { document.getElementById( 'review_text_full' ).style.display = 'block'; document.getElementById( 'review_text_short' ).style.display = 'none'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('less'); }; } else { document.getElementById( 'review_text_full' ).style.display = 'none'; document.getElementById( 'review_text_short' ).style.display = 'block'; document.getElementById( 'review_title_link' ).onclick = function() { showHideReviewText('more'); }; } } ...with a dialogue "try reinstalling HP software", and needs a reboot
- sometimes it scans and after conversion to pdf every page is blank
- very occasionally it scans a document properly
*If the sheet-feeder jams is says to refer to the documentation to clear it, which doesn't exist. There is no way to clear the jam except to pull hard & hope. No levers to release it like one would expect.
*Frequently has error ...
...cycled to work again.
Everything has to be started by pressing a button on an application called "HP Director". There are 4 apps started from this:
1) Scan Picture
2) Scan Document
3) Make Copies
4) View & Print
also Help
also Settings (which are used in conjunction with settings found in (1) and (2)!)
- Each application has to be exited to return to "HP Director"
its a worst scanner
and prone to jamming problem
Jun 09, 2010 | HP Scanjet 5590 Flatbed Scanner
Screen display 290 jam remove original
290/291/292 Scanner Jam
1 Open the ADF top cover.
2 Remove the jammed paper by gently pulling it straight out.
3 Close the ADF top cover, and then load the documents back into the ADF.
Note: To prevent document jams, use the scanner glass rather than the ADF for thick,
thin, or a mixed set of documents.
4 Press Start to resume.
Nov 12, 2009 | Lexmark X342n All-In-One Laser Printer
HP Officejet Pro 8500 has a paper jam. Can't get
Hi! I will be glad to assist you in this issue, here is the link that will fix the issue:
Paper Jam' Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01617494&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Carriage Jam' Message Displays on the Control Panel Display
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01618201&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3752459&lang=en
Oct 11, 2009 | HP Office Equipment & Supplies
Samsung SCX 4521F All-In-One Laser Printer Logo
60 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
