Question about HP Pavilion 513c PC Desktop
Sound card wont perform
When i hook up the cord for the monitor it wont work
  • HP Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
Posted on Oct 29, 2012
My compaq fs7600 monitor wont turn on
Hook a spare monitor to the computer, if no change! the Video Graphics Card is suspect usually built into the motherboard. But if spare shows picture, the problem lies in the HP monitor, as a last resort change the video cord from the computer to the monitor "if possible" to rule out something simple.
Mar 15, 2012 | HP Compaq FS7600 17" CRT Monitor
Black screen Nothing comes on
Check the power cord get another cord to check it. Or if the green light is on it is getting signal but no visual take the monitor over to a working computer you know of and hook it up if it works then you are dealing with the video card issue. Or take another monitor that works and hook it to the suspect computer and if it does the same thing does not come on it is a video card issue. If it turns on then it is the monitor that has gone bad. Lets hope not? John
Jan 13, 2011 | HP f1905 19" Flat Panel LCD Monitor
When I turn my PC on you can hear it come on but the screen is black.
It sounds like you might have a problem with your video card. If you turn it on and see nothing, not even the gateway logo, than you either have a video card issue or a monitor issue. Hook up the mahine to another monitor to test.
Jan 04, 2011 | Gateway Computers & Internet
Wont work
Please make sure to check the following: 1- Hook up a different monitor to make sure that the video card on your PC is working properly. Also set it to a low resolution
2- Ensure that the power supply cord has a good solid connection with the adapter (if you have one) and the wall outlet 3- Make sure your monitor is on (some have more than one ON button) 4- Make sure that the data cord between your computer and the monitor has a good connection
Apr 24, 2010 | Compaq FP 7020 17" Flat Panel LCD Monitor
ViewSonic VX2235WM turns on than screen goes blank changed power cords cable cords viedo card cpu still same problem
The problem is most likely the monitor itself. Hook up an old monitor (usually someone has an old monitor laying around) if the computer works with another monitor you'll know for sure.
Look at your monitor using a flash light at an angle, if you can see a picture in the background you have a bad inverter.
Nov 28, 2009 | ViewSonic VX2235WM Monitor
I have a gateway 383gm its worked fine for the past 4-5 years and the other day i turned it on and the monitor wont come on. I hooked the monitor up to another computer and it powers on fine (so monitor...
Have you already tried removing your memory card stick?If not, then remove the memory and then the pins of it using an eraser of a pencil and then put it back on..,reset again the bios and be sure to connect all the cords correctly of your computer and then power on. Hope this could help you.. Thanks..
Oct 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Monitor on power save mode and using wireless keyboard and mouse
This sounds like the monitor is not reading a signal from the computer. I had the same problem when I installed a DIV cable from my old VGA cable. The video card was still sending the signal via VGA port instead of the DVI port of my video card. You should cheack the cable to you're computer and what port is being used. If everything is hooked up correctly then there might be a problem with the cable. Other then that it could be you're video card. If the hard drive is running and everything is running fine then what I said should be whats wrong. If nothing works go back to the shope and tell them the new problem you have.
Sep 10, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My monitor is connected, as is my graphics card, but when I turn my computer and my monitor on, it says that there is no input signal.
Hello there:
I would start by trying a different monitor to eliminate the possibility of a faulty monitor.
if nothing happens you are going to need to investigate the video card. you can turn off the computer and open up the case and remove the power supply to the motherboard cord.
now remove the video card from the board and check to see that it isn't damaged or dirty . you can try to put it into a different slot if you are able to. now just hook up the powersupply cord back up to the motherboard and hook up the monitor to the computer and power up the computer than the monitor and see if it works if still nothing than i am sorry but you will be needing a new video card ok? i really hope that this is very helpful
best regards mike
Jul 31, 2009 | Computers & Internet
Hooked computer up wrong.
your cable that looks like a y the y side goes to your monitor for right and left the bottom of the y single plug goes to yyour tower sound jack usually card marked with sound icon circle with waves. put your music on ,on pc put the jack in one plug at a tme til you hear your music, you probably have three or four jacks.
Dec 04, 2008 | HP Audio Players & Recorders
HP Pavilion 513c PC Desktop Logo
41 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
