Hello, I have this Sony PS3 3D LED Display and it had worked just fine for few months. Day before yesterday, when I turned it on it's giving me that blinking red light which I had do described in
    Genius:
  • 2,432 Answers
Tried with unplug and re plugged doesn't work?.
Posted on Oct 29, 2012
Fix-4U
  • 293 Answers
SOURCE: no display problem
Rajpal,
Your backlight inverter are busted, need replaced a new inverter. Have a nice weekend!
Posted on Oct 04, 2008
chinna_1977
  • 65 Answers
SOURCE: whenever system restart , led blinking, no display
15" Monitor warranty period 1 year from mfd date.
17" Monitor warranty period 3years from mfd date.
Posted on Oct 11, 2008
SOURCE: Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Posted on Dec 26, 2008
  • 298 Answers
SOURCE: Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: monitor light blinking
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
I have a D-link DSL-2750U router worked fine till yesterday, but now its power led keeps on giving a red light it should give green a second or two later but it keeps givings
Reset router. There are two resets. A simple push reboots and holding it in clears all custom settings. Try the first.
This is a quick fix and usually does it. Test with network cable and work your way backwards to modem if you still have problems.
Nov 11, 2012 | Computers & Internet
A few weeks ago my 97 cherokee's check guage came on. Voltage dropped to zero and then eventually drained battery. I removed altenator and had it tested. It tested ok and I reinstalled. When I started it...
Hello, Yes it sounds as if it is a computer problem. There is no way to bypass it you will have to replace the engine computer. Good luck and feel free to ask anymore questions about this and I will do my best to answer them.
Jan 29, 2011 | 1997 Jeep Cherokee Country
2 year old, well maintained Myo XP that has never been submerged or been seriously soaked. Yesterday, I turned it on and 1 second later it went out. Batteries are good. Wiring solid. No battery level...
Its a bit late now i know ; although somebody may get some use out of the information 'that' the 'myo xp' has a manufacturers warranty of 36 months (3 years),
mine has gone the same way after 18 months so its about to go ,back to its roots !
Nov 30, 2010 | Petzl Myo XP LED Headlamp
The power light is red and the bulb light is blinking red
OK...Did you replace the lamp with a Sony original? If you did, then carefully check that the door is closed properly.
May 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
How to unfreeze mp3 player
it may be in lock mode and that can be caused by the battery running dry
Jan 08, 2009 | Philips GOGEAR SA6045 MP3 Player
be sure you have the headphones plugged into the right hole, plugging into the usb can cause something similar to me.
Dec 15, 2008 | Philips GoGear SA261 MP3 Player
SONY WEGA KV27FS120 WON'T TURN ON, LED BLINKS A FEW TIMES
YOU HAVE A PROBLEM WITH THE DRIVE IC OR HORIZONTAL CIRCUIT. TAKE IT TO AUTHORIZED SONY SERVICER.
EST $150.00 PARTS AND LABOR
Nov 25, 2007 | Sony FD Trinitron WEGA KV-24FS100 24" TV
The monitor would not turn on. Only the orange LED does.
1. Make sure the monitor cable is fully plugged into the computer. 2. If the new monitor works fine, The connection between the previous monitor and the PC was bad. Reconnect the original monitor to the PC and make sure that the connection is snug. Tighten down the video connectors until they are snug. Try again. good luck..
Jan 06, 2006 | Hitachi CM772 19 in.CRT Conventional...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
