Yamaha MM6 61Key Synthesizer Keyboard Logo
Posted on Oct 29, 2012
Yamaha MM6 Driver Software Error 250001
The setup wizard says to cancel the automatic driver software installation when I plug my keyboard into my laptop but I don't know how to do that. I've tried numerous times but it installs automatically everytime. I've also tried going into devices and going into driver software installation and click the "No, let me choose what to do" option but that doesn't work. I'm running a Windows 7 64-bit. Can anyone help me?
2 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on Jun 14, 2011
SOURCE: My Yamaha mm6 doesn't work
There is probably a setting that is wrong. The left channel is the default for mono operation. Look in your user manual regarding "PAN" which controls the output going side to side. You MAY be "panned" clear to the right. When you plug into the left, it is the default so in spite of being panned right, they would send signal to the left IF nothing is plugged into right.
Anonymous
  • 59 Answers
  • Posted on Aug 26, 2011
SOURCE: How hard is it to repair a sticking key on the
It kinda depends on if a hammer is broke or key is broke. Or if a foreign object is stuck in there. Typically not hard if you can remove screws and remember how they go back in. TypicAlly the bottom panel comes off keyboards ( start by removing those screws ) or the top case will fold up ( still bottom of keyboard screws ) then multiple screws to realease keyboard assembly. May have to disconnect some wires/ ribbon cables so have a sharpie ready to label to ensure correct reassembly. Then it's all about if they have separate keys or a keytree or sometimes just removing ba key and reseating fixes sticking problems. Get yourself a can of blow off or contact cleaner just in case. Not sure who locally to you sell parts but you can always call manufacturer and ask who does their distribution for parts.
No sound blank screen has power not used for 5 years product is a yamaha mm6 keyboard
Your battery has died and you've lost the sound info, Contact Yamaha in your area to find a service center to place the battery and reload the data.
Yamaha mm6 transposing by itself
Probably the transpose button on your keyboard has become short. You need to clean the contact by a cleaning agent such as WT-40 or similar one. If not, you need to change the button.
Yamaha MM6 Factory reset?
My Yamaha MM6 Synth is showing blank (white) screen when switched on. Keyboard sounds and banks are working. Everything looks nice but not showing any details on screen. Any help.....
1helpful
My yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
My Yamaha mm6 doesn't work stereo, just mono. when u put 2 cables it works from right channel, but if u put to the left channel, works from the left. I don't get it.
I cant connect my yamaha ypt 320 to my pc using the midi
Assuming you have a MIDI interface on your computer, you need to connect the MIDI cables between the keyboard and the PC. You cross connect, that is, in to out and vice versa. You will ALSO need the driver software for the interface in the PC AND most importantly, some software in the PC to handle the MIDI for instance to record.
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
