Question about NetGear RangeMax WPN824 Wireless Router
I have my router but i dont know what is it's version
    Problem Solver:
  • 7 Answers
If it doesn't indicat on the router itself, you can call NETGEAR 1-888-638-4327. Give the tech your serial number and they will be able to determine the version of the router.
Posted on Dec 18, 2012
Runtime error in setup script line 3 @address 77C0154D in module 'version.dll'.
sounds like malware, download and run malwarebytes from malwarebytes.org. then download and run combofix from bleepingcomputer.com. you'll have to reset your winsock as well by downloading and running winsockfix.exe you can find it by googling. use a different computer and put it on a flash drive :)
May 31, 2012 | Linksys Wireless-G WRT54G Router
How to connect new devices to Thomson router (TG585 v7)
Using a command prompt and telnet:
Type in telnet 192.168.1.254 and hit Enter. If this doesn't work, then you don't have Telnet installed and will need to go to Start ? Control Panel ? Programs ? Programs and Features ? Turn Windows Features on or off ? Ensure TELNET CLIENT is checked and click OK.
When prompted, the default username is Administrator (case sensitive) and the default password is either blank or the serial number of the router (case sensitive):Click to open image
Type in "connection unbind application=SIP(TCP) port=5060" (without the quotation marks) and press Enter. If you get a 'unknown command' message returned once you press enter, then type in: "connection unbind application=SIP port=5060" (without the quotation marks)
Type in "saveall" and press Enter to apply and make this setting permanent
Feb 27, 2017 | Computers & Internet
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
Just recently, my internet has gone haywire. My single wired connection works fine, but all my wireless connections have gone down the drain. FF version 5 keeps popping up with "Content encoding...
First I would need to know the model of the router. I would go on netgear's website and see if there is a firmware update for your router or try a different wireless router. If the problem persists then it may be an issue with your internet provider/modem.
thank you,
Lee
Jul 18, 2011 | Computers & Internet
I dont have installation driver
Router does not require driver to be used, all you have to do is to install the hardware and configure it.
1. You have to know your hardware version, so you can download your materials.
There are 5 version of your TEW-432BRP.
2. Click the link below, If you already know the version.
(Main).
(TEW-432BRP D1.2R/D1.3R)
(TEW-432BRP D1.OR/D1.1R)
(TEW-432BRP C1.xR)
(TEW-432BRP Bx.x)
(TEW-432BRP A1)
3. Download User Guide and Easy Go CD Files.
4. User Guide will help you to configure your router from start to end.
If problem persist just post and give a brief explanation on the problem.
Hopefully this helps
Thank you for posting.
Jul 09, 2011 | Trendware TEW-432BRP Wireless Router...
I have my wii all set up except for the internet. a guy came out & fixed my wireless but now its asking fr a password & i dont know what that would be... i thought maybe on the back of my router...
If it's a Linksys wireless router, then the default password is "admin" in small letters (no caps). Don't worry about the username, it won't require it, until you get into the settings. If it's a Belkin, then Google: Belkin default password, and it will then give you a list of default passwords, depending on your model type. Good luck.
Jul 05, 2011 | Computers & Internet
I have just purchased an iPad 2 and it's asking me for my Netgear password; the default password doesn't work, so I must have changed it - but I can't remember what I changed it to!
so then you can simply reset the router so to go back to its default password ...or if you want to know your recent password, simply use your computer that is currently connected to your router and is working...then follow the steps in this link http://netspace.custhelp.com/cgi-bin/netspace.cfg/php/enduser/std_adp.php?p_faqid=508&p_created=1216184248 Configuring your Netgear DG834G & DG834GV Wireless Network
Note: you dont need to configure the wireless just check the password you have setup there so you can connect your ipad wirelessly...
Thats it!! (-_-)
Jul 05, 2011 | NetGear DG834G Router
Need to change seetings but cannot login to router config page because i dont have a password or username.
you did not gave us the router version
so look here for your password http://www.phenoelit-us.org/dpl/dpl.html
scroll down to D_LINK and look for your version and your use and password.
If that didn't work, that means that someone has already changed the password.
Go to the router and reset it and the default password should be here
Could have helped more if the router model was mentioned.
Please rate 4 stars if this helped you. Thank you
Apr 25, 2011 | D-Link Computers & Internet
NetGear RangeMax WPN824  Wireless Router Logo
37 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
