SOURCE: e66 shows "Remove Memory Card and Press OK"
Your memory is not inserted properly. Take it out carefuly, and check if inserted correctly. If problem still there format the memocard - it will also delete its content.
Testimonial: "ty"
SOURCE: Changed nokia e66 housing.. and now offline
I have the same problem..i replaced the sim band and the problem still persist.. what to do ? :' and my wifi dont detect any network :' wtf?:((
SOURCE: I can't use any sim
you can use it after unlock the phone , you can unlcok it here http://www.onlinegsmunlock.com/nokia-e66/rs7wp9/
SOURCE: my nokia e66 suddenly says
The problem is because the memory card is loosely in place. Take the memory card out then push it back making sure that it fits the slot perfectly then you can access your files again with no problem.
Also make sure that you are following the correct way of putting it in as illustrated in the carving at the back of the phone.
SOURCE: my e66 can't recognize my
my nokia e66 can not recorgnised my sim card
how do i solved on it
