Question about Element Electronics Televison & Video
Wont turn on
Press on button nothing happens
  • Element Elec... Master
  • 8,617 Answers
If you dont get a power light then chances are its a shorted power supply which has blown the main fuse. Check the fuse if blown replace the power supply board. You can get replacement power boards from www.tvrepairworld.com
Posted on Oct 29, 2012
Bike wont start, turn the key n everything lights up as normal, press the start button n just nothing
It could be the link from the starter button to the ignition coil. If you can check this for a current it should give an indication of the problem.
Jul 11, 2015 | 2005 Yamaha XVS 1100 Dragstar
Wont turn on
Mine doesn't turn on either.
I keep pressing the power button but nothing happens.
Press it longer than 3 second.
Press it harder than normal.
Also press the reset button at the back.
Nothing works it just won't turn on.
The power LED does turn on, but the heater and the rest of the display doesn't work.
Mar 30, 2014 | Tefal Ultimate EZ Clean Pro Deep Fryer
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
May 14, 2017 | LG WM2077CW Laundry XL Front Load...
The power button wont work
Switch will have to be replaced,
Nov 12, 2012 | Memorex MVD2028 DVD Player
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
Oct 17, 2012 | Traxxas Velineon VXL-3m Speed Control
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
My iphone 2g wont turn on, i replaced the lcd, it worked ok, my batter was low. so it died and i was trying to turn it on, but it wont turn on. when i plug in the wall charger nothing happens,but when i...
I have a feeling that when you ran the battery down it is now struggling to get and hold a charge.
If you have a friend with a similar battery perhaps try that, or go to a mobile store and ask them to try a new battery for you.
Nov 09, 2009 | Apple iPhone 3G
Kawasaki zzr400 (1994 model),streetfighter wont start
check starter solenoid.see if getting power to starter side when pressing button .if yes check if power to starter w/ test light when pressing button.if power there check starter,also motor, will it turn manually or is it seized.if no power to starter side of solenoid, jump across solenoid posts w/ a large screwdriver -motor will probaly turn over,w/ key on.if small wire to solenoid has power when pressing start,solenoid bad,if no power, wiring or start button bad.
Jan 22, 2009 | 1997 kawasaki ZZR 400
My ipod nano wont do anything
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Hope this helps
Jul 19, 2008 | Apple iPod nano 3rd Generation
Televison & Video Logo
101 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
