Question about Vacuums
What sort of switch can I replace it with? - Vacuums
  • 4,340 Answers
Bruce, if you are talking about a vacuum cleaner, you want an exact replacement switch. They're not too costly.
Posted on Oct 30, 2012
I have the Hoover U6485900 and the brush rollers keep spinning even when the vacuum is in the upright position. I have replaced both belts hoping that would fix it. Help!
depending on your exact model this is supposed to happen even when it is up right since the vac motor does two things besides just sucking up dirt but in order to prove that i would need some photos (photobucket links or any other imaging online service is welcome to be used to see the exact model vac it is) now if it has like a two stage mode switch in this model it could be that the two stage switch is a lil bad but i have seen where people have done mini mods to save cash and sort of make their own sorta two stage switch with two switches and a bypass to just run the main motor for sucking up dirt
Jan 05, 2017 | Hoover Vacuums
Dc7 keeps turning off
Assuming you mean the motor runs for a short while after switch on, then cuts out, this is indicative of a faulty motor - it has an over-current sensor that shuts off to prevent overheating and possibly fires.
You need to have the motor replaced. It is possible to do this yourself if you have very good DIY skills and tools, or a repair shop should be able to do it for a reasonable fee. Replacement motors are available on eBay, and if you search YouTube, there are loads of "how to" videos on this sort of stuff.
Jun 28, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Where is the reset button on a dyson dc41 ?
There is no such thing as a reset button on a Dyson.
If you have a problem where the motor cuts out shortly after switching on this is indicative of a faulty motor - it has an over-current sensor that shuts off to prevent overheating and possibly fires.
Jun 28, 2014 | Dyson Dc 41 Ball
I have hoover S3670055 when I turn it on the power head does not come on when when you press the switch on
I too am having difficulty. Everything seems fine electrically. I only get about 350 mv AC Power with the switch off and 1.7V AC with the swiitch on. I would think the power brush head would require DC voltage of some sort.. Like 12V???
Sep 26, 2011 | Hoover S3670 Bagged Canister Vacuum
Need to know how to replace the micro switch
We wouldn't recommend that you attempt this sort of repair yourself. If you feel the microswitch needs replacing, it's probably best if you get in touch with us directly so we can provide the assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 13, 2011 | Dyson DC18 all floors Bagless Upright...
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
Need to purchase an on/off switch for my infinity nv31 but am having trouble finding one....the local vacuum store will not sell it to me unless I pay the 80 dollar fee to diagnose what I already know...I...
Is this some sort of special switch? Are you concerned with cosmetics?
If not, Just find a spst switch, drill a hole next to the one where the old switch was and replace. Of course, make sure there is room for your 'new' switch first.
Mar 02, 2009 | Euro-Pro NV31 Infinity Vacuum
I took my Kirby G4 outer covers off, vacuumed the inside to remove the dust and now it refuses to turn on. Is there some sort of redet switch?
I'm pasting this from another solution I posted. Hope it helps:
There are a few things to check:
There are safety switches mounted on the body of the machine designed to prevent the machine turning on when it is not fully assembled. Ensure that your bag unit is snapped completely into place, (with the rear of the emptor assembly nearly flush with the body of the machine,) and that the front nozzle assembly is mounted correctly.
Also check that the power cord (immediately aft of the bag unit,) is pushed completely into the machine.
If the switch does not feel responsive, it can either be that the little metal "pole" (for lack of a better description) is not attached to the main switch assembly correctly, which will require you to open the entire housing to check.
Those are the simple things to check, otherwise it may need a switch, cord, or motor replacement. Checking continuity on these items with a VOM will allow you to determine the cause.
-R
Sep 10, 2008 | Kirby Vacuums
On / Off switch
Had the same problem and found that the interior switch was to stiff and the plastic activator would just pass over it. Solution was to pull the three screws that ho;d the activator switch, pull the interior switch and replace it. This is a lot easier than it sounds.
May 20, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
