Question about Pool & Spa
Need manual for Aquaswim pool filter system model 610
Have just moved to a place with a pool and need operating manual for Aquaswim pool filter model 610.
kstfas
  • 75 Answers
SOURCE: Purchased a sf-610 today floor model, no manual
Hi, I would start with the store where you bought it. Sounds like you got an incomplete unit. If not, they may be able to get a manual out of another unit. Don't see any manuals on line but 1-800-330-0388 is their phone number for customer service. Explain to them the situation and ask for technical services. They should be able to send you a manual and answer any questions you have on the unit. Write them all down before you call them. Hope I have helped. kstfas
Posted on Aug 27, 2007
jyackle5
  • 8197 Answers
SOURCE: Need operation manual
here is the manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=CER3520&siteCd=MCF
please rate if it is helpful when done. good luck
Jon
Posted on Dec 16, 2008
tcdchameleon
  • 9 Answers
SOURCE: operator and parts manual
Robin219,
I have found an owners manual on E-bay for 7.99 + Shipping. Will this suit your needs? The Auction on it ends on Sunday the 25. Take a look at http://cgi.ebay.com/McCULLOCH-CHAIN-SAW-PARTS-MANUAL-FOR-PRO-MAC-610-%2F-650_W0QQitemZ360124205014QQcmdZViewItemQQimsxZ20090119?IMSfp=TL090119129004r31016 Hope this works out for you.
Posted on Jan 21, 2009
  • 46 Answers
SOURCE: I NEED THE OPERATION MANUAL FOR FNC1 MODEL
I know it is a long address, but I got it from Krupsusa.com
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={F506FE01-D7EC-414A-BEC1-AE53E62990C6}&SelectedProdRef=FNC1
Posted on Mar 25, 2009
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
Posted on May 22, 2009
Trying to put pump system together. Do we remove the drain screen before adding sand?
Our terminology is not coinciding...
Follow these steps...
  • 1st - understand that a pump moves water thru your system.
  • A filter cleans your water
Sand does not go into a pump.
sand goes into the filter.
  • when adding sand into filter tank, top valve is not in place, you Need to first add water, to cover the laterals at bottom
  • Then PLACE a cap or something/anything, over the stand pipe, so NO sand goes into that pipe! IMPORTANT! Begin to add sand.
    • Do this slowly, being very careful to NOT disturb position of stand pipe! Do NOT Lift it or allow it to rise up! Keep it centered!!
  • Add required amount of sand
  • Remove stand pipe cover/cap that placed
  • Install valve onto tank
  • Complete plumbing in-out of the valve
    • Presuming you have the plumbing complete from and to pool?
    • Pool suction port to front of pump. Out of pump into 'Pump' port of filter valve
    • Out of 'Return' port to pool
GOOD LUCK
May 31, 2015 | Waterway Pool & Spa
What is the recommended end-of-season maintenance for the chlorinating pump?
According to the Intex website, the following maintenance is required for this product:
The Intex Saltwater Pool Systems are designed to operate with a minimum amount of maintenance. It is recommended to always turn the pump on prior to turning on the Saltwater Pool System (see Owner's Manual) unless the chlorine generator is part of a combination pool and filter set, to ensure that air pockets are eliminated from the hoses, and that water is flowing through the unit. In addition, the electrolytic cell should be examined and cleaned if necessary. The frequency of cleaning will depend on the local water conditions, pool usage conditions, and length of time the Saltwater Pool System is operated each day. (See Owner's Manual.)
The Intex Saltwater Pool Systems contain several features that minimize maintenance requirements:
1.) An automatic self-cleaning cycle: The Saltwater Pool System automatically undergoes a self-cleaning cycle to maximize the operating length of the electrolytic cell.
2.) Safety diagnostics: the Saltwater Pool System will alert the operator to three conditions that could result in poor operation: Low water flow through the unit, Low Salt level in the pool water, High salt level in the pool water. If any of these conditions exist, the system will sound a buzzer, and flash a digital code on the control panel (Model 8110) or a Red LED will light up. (Model 6110).If the condition is not addressed, the system will automatically shut itself off to prevent damage to the unit.
Sep 11, 2011 | Intex Automatic Salt Water System for ...
Vacuum gone slow moving.All parts have been checked and filter cleaned. No improvement in suction.
You need to check your water flow with the water flow gauge. The black disk should be between the min and max settings. If it is indicating a min reading, that is indicative of a problem with your pump and filter system and not the pool cleaner itself. You will need to check your pump to make sure that it is primed and operating correctly.
May 24, 2011 | Hayward Navigator Pool Cleaner
Need instructions for proper start up/operation of filter
For the actual filter try this manual:
https://www.hayward-pool.com/pdf/manuals/Manual145.pdf
For the valve atop the filter try this one:
https://www.hayward-pool.com/pdf/manuals/manual18.pdf
If these are not the same as what you have please add a comment with the model number off your filter tank label and your valve.
John
May 04, 2011 | Hayward SAND FILTER, PRO SERIES
How do you work the pump? We have just moved and new house has a pool with this pump but we have no idea how to use it and the pool is green.
Your pool is green because of algae. You need to run the filter 27/7 until it clears up ... Bring the chlorine up to about 10 PPM. When the filter pressure increases 10 to 15 #, backwash the filter until clear in the site glass then resume filtering.
If you have a multi-port valve, ONLY turn it in a clock-wise direction and never with the pump on.
If this is new water ... the green is metal in your pool. At this point, the only thing you can do is run the filter 24/7 until it clears ... Do not add any Chlorine until the green is gone./ You may want to consider using a filter flock product.
You should get an indoctrination from your professional pool supply place on the ins and outs of pool operation before you go much further.
I hope this helps you ... if you have more questions ... you can seek me out at this site.
Thanks for your interest in FixYa.com
Feb 05, 2011 | Pool & Spa
Do laterals in a sand filter move in a circle
Try consulting the users manual for these pool filters. It has a diagram of the parts of the filter and how they work. It should help you out.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 20, 2010 | Hayward Pro Series 18" Above Ground Pool...
Pool pump inflow/outflow handles and their position?
GO TO YOUR LOCAL POOL STORE AND SEE IF THEY HAVE A SIMILAR UNIT . IF THE FLOW IS NOT GOOD YOU MAY NEED A NEW DIFFUSER $20... .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
Need to know how to backwash the pool filter
Depends ...
There are two primary valve styles ... a "multi-port" and "push-pull". Never change a valve setting with the pump running.
Multiport has a handle that goes around in a circle (only move it clock-wise). You should go to your pool place to identify this kind of valve and get new lables. Push-pull goes up and down. Up is filter - Down is back wash.
If you will study your system, some things will become evident to you .
Your pump pulls water from the pool through the pump ... out of the pump into the filter. Through the filter, back to the pool. You might be heating the water (would be after the filter) and you may be adding sanitiser (after the heater). One suction - two discharges (oh, the other discharge is to waste.).
Recap ... water out of the pool into the pump - out of the pump throuth the control valve to the filter - out of the filter to the heater then to the sanitiser then back to the pool.
Any help?
BTW ... I am a volunteer question catcher at FixYa.com. At my job, among other things, I am a Certified Pool Operator (CPO), certified by the National Swimming Pool Foundation.
May 14, 2010 | Pool & Spa
Send pictures of the valve assembly to info@coastsideservices.com and we will try and assist you with your need.
Mar 23, 2010 | Pool & Spa
Pool & Spa Logo
863 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
